mike regish wrote:
But temperature *is* a measure of energy. It is a partial measure of energy. It doesn't measure potential energy. Matt |
This thing has me curious. I just found this little tidbit. See what you
think. It comes from the work done compressing the gas in the cylinder. The Temperature changes in response to compression due to addition of more molecules of air to the closed, fixed-volume cylinder. Work is produced. Temperature rises. The temperature must change by following Ideal Gas Law: P V = N k T Where P = pressure, V = volume, N = number of gas molecules, k = is Boltzman's constant and T is Kelvin. The equation must balance. Pick any system of gasses at a specific pressure, temperature and volume. Change any of those four conditions, the others must change proportionately. See also, http://scienceworld.wolfram.com/phys...ealGasLaw.html mike "Matt Whiting" wrote in message ... mike regish wrote: But temperature *is* a measure of energy. It is a partial measure of energy. It doesn't measure potential energy. Matt |
mike regish wrote:
This thing has me curious. I just found this little tidbit. See what you think. It comes from the work done compressing the gas in the cylinder. The Temperature changes in response to compression due to addition of more molecules of air to the closed, fixed-volume cylinder. Work is produced. Temperature rises. The temperature must change by following Ideal Gas Law: P V = N k T Where P = pressure, V = volume, N = number of gas molecules, k = is Boltzman's constant and T is Kelvin. The equation must balance. Pick any system of gasses at a specific pressure, temperature and volume. Change any of those four conditions, the others must change proportionately. See also, http://scienceworld.wolfram.com/phys...ealGasLaw.html mike "Matt Whiting" wrote in message ... mike regish wrote: But temperature *is* a measure of energy. It is a partial measure of energy. It doesn't measure potential energy. Matt Yes, so what is your point with respect to temperature as a measure of energy? Matt |
Not a thing.
mike Yes, so what is your point with respect to temperature as a measure of energy? Matt |
mike regish wrote:
Not a thing. mike Yes, so what is your point with respect to temperature as a measure of energy? Matt OK, I was trying to figure out the connection and didn't see one. :-) Matt |
My point was that I don't understand where the confusion is as to where the
heat comes from in filling a scuba tank. You are cramming a whole crapload of molecules into a confined space and it makes heat. If you cram those molecules into that space quickly (with respect to how fast you can dissipate that heat) you get a VERY hot tank. This formula just explains it better to me, though it doesn't seem to satisfy some as an explanation. It's the same as a deisel engine except that rather than increasing the number of molecules of air, the deisel decreases the volume of a fixed number of molecules. It does it rapidly, so there's no time to dissipate the generated heat through the cylinder walls, and the air heats up enough to ignite the fuel when it's added by the injector. If you filled up the scuba tank very slowly, giving it time to give up its heat to the surroundings (they're filled in a water tank, no?), then it would not get so hot. I'm guessing that they are filled from a pressurized tank. That TANK will get cold due to the decreasing number of molecules in it as the scuba tank fills. I guess I just don't get where all the confusion comes from. What do scuba tanks get filled to? Something like 2 or 3 THOUSAND psi, no? mike "Matt Whiting" wrote in message ... mike regish wrote: Not a thing. mike Yes, so what is your point with respect to temperature as a measure of energy? Matt OK, I was trying to figure out the connection and didn't see one. :-) Matt |
heat comes from in filling a scuba tank. You are cramming a whole crapload of molecules into a confined space and it makes heat. Yes, but you are cramming a whole crapload of =cold= molecules into that space. The heat generated seems like it wouldn't be enough to compensate for the cold of the inflowing gas. That gas is cold because it expanded from the other tank, which was under even higher pressure. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
"mike regish" wrote in message
... (they're filled in a water tank, no?), That practice tends to be discouraged these days... It has been determined that a slow fill is better... There are some that say that especially with aluminum tanks, the water tank method is especially bad since the temperature of the surface of the metal might be radically different than the temperature of the inner metal thus increasing the chance of fractures in the metal... |
PLEASE DON'T FEED THE TROLL | Darkwing | Piloting | 2 | March 16th 06 03:46 AM |
Troll of the year award | Skylune | Piloting | 78 | October 7th 05 08:10 PM |
Art...Best Troll Ever? | [email protected] | Military Aviation | 7 | September 8th 04 11:55 PM |
