Sylvain writes:
is this the reason why the night flying requirement for an initial commercial in a multi- does not have to be solo? I mean, did the FAA tailor the rules to fit the insurance requirements? What happens in aircraft that require a crew of two? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
What happens in aircraft that require a crew of two? The FAA in its infinite wisdom, has it covered; airplane that require more than one pilot tend not to be used as primary trainers though. Question: is there any aircraft out there that require more than one pilot but does not require a type certificate? --Sylvain |
A light twin on FAR 135 IFR w/o an autopilot
"Sylvain" wrote in message t... | Mxsmanic wrote: | What happens in aircraft that require a crew of two? | | The FAA in its infinite wisdom, has it covered; airplane | that require more than one pilot tend not to be used | as primary trainers though. | | Question: is there any aircraft out there that require | more than one pilot but does not require a type certificate? | | --Sylvain | |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
