Coordinated turns and the little ball
Old October 9th 06, 08:39 PM posted to rec.aviation.piloting
Walt
Default Coordinated turns and the little ball
Dudley Henriques wrote:
"new_CFI" wrote in message
I guess he means precession. If you roll fast enogh, your aircraft
acts as a gyroscope. Now apply a force perpendicular to the roll axis,
and the result will be a precession motion which can be pretty
impressive.
ok, I knew it must have soemthing to do with a gyro....I couldnt reason it
out...but this makes sence. I hope your right...or else ill just have to
go back to being confused again.
That's a shame it makes sense, as its not correct, and understanding all
things related to flying are worth knowing as a flight instructor. There's
really no reason for any instructor to be "confused" when a little research
will enhance understanding.
If you are actually interested in inertia coupling, perhaps a little bit of
research might bring you up to speed on it. If not, please accept my sincere
apology for having mentioned it.
Dudley Henriques
Googling "inertia coupling" I found this, which cleared things up a bit
(at least for me):
A few of the experimental aircraft encountered a new type of behavior
known as inertia coupling, a behavior that was not fully appreciated
until the F-100 and F-102 also encountered it. Inertia coupling
resulted from the tendency of the new generation of high-speed aircraft
to concentrate most of the weight in a long thin fuselage, a departure
from the distribution of subsonic fighters. The X-3 configuration is an
excellent illustration. Even though its high-speed performance was
disappointing, the X-3's unanticipated susceptibility to loss of
control from inertia coupling contributed to understanding the problem.
With much less weight in the wing and tail, the dynamic motion in a
maneuver could cause the inertia of the fuselage to overpower the
aerodynamic stabilizing forces of the wing and tail. In the worst cases
the pilot lost control and the resulting abnormal air loads caused
airframe structural failure. The early F-100A models are remembered as
a classic example of susceptibility to inertia coupling, although the
initial F-102A models also encountered the problem.
--Walt
Bozeman, Montana
Old October 9th 06, 08:53 PM posted to rec.aviation.piloting
Dudley Henriques
"Walt" wrote in message
impressive.
it
to
There's
research
of
sincere
Dudley Henriques
(at least for me):
--Walt
Bozeman, Montana
Sounds like a winner to me. Thank you for taking the time and interest.
Dudley Henriques
Old October 10th 06, 12:33 AM posted to rec.aviation.piloting
Morgans[_2_]
Dudley Henriques
I'm not quite sure what that means, as far as what motion the fuselage actually
takes.
Does the nose veer off of the line of flight, or does something else happen?
Jim in NC
Old October 10th 06, 12:45 AM posted to rec.aviation.piloting
Jim Macklin
Lomcevak Tumble - Aerobatic Maneuver Demonstrations -
Fighter ... Student Air Show Pilot, Carl, gets cockpit
instruction on flying the Lomcemvak tumbling maneuver.
Fighter Combat International lists our Adventure Home ...
www.fightercombat.com/vid_03Sep04.htm - 23k - Cached -
Similar pages
[PDF] Maneuver Name: File Format: PDF/Adobe Acrobat - View
as HTML
Maneuver Description: The 45° Up Lomcevak begins
with an aggressive pull to. the 45° up line "A". Once
established on the 45° up line, the aircraft is ...
www.fightercombat.com/maneuvers/Lomcevak.pdf -
Similar pages
All about aerobatics-Freestyle-torque roll, Knife edge spin,
flat ... There are variations for lomcevak, especialy in the
way to begin (level description lomcevak , 45° description
lomcevak ou vertical description lomcevak ). ...
rafaero.free.fr/voltige4-eng.html - 12k - Cached -
Similar pages
"Morgans" wrote in message
motion in a
overpower the
the worst cases
loads caused
time and interest.
| Dudley Henriques
| takes.
| Jim in NC
Old October 11th 06, 10:17 PM posted to rec.aviation.piloting
Morgans[_2_]
Similar pages
So the motion of inertial coupling is similar to a lomcevak? That I understand.
Thanks.
Jim in NC
