My new flying rule - bring camera
Old October 9th 06, 10:40 PM posted to rec.aviation.piloting
Jim Macklin
Default My new flying rule - bring camera
About 1 minute of angle if there is good light and contrast.
"Judah" wrote in message
| "new_CFI" wrote in
| I didn't have my camera the day I saw the 747 converted
to water tanker
| do a test drop...a waterfall from one end of the runway
to the
| other....it was awesome...all I have now is a memory of
what it looked
| like..can't show people a memory.
| Now THERE's an idea!
| Someone needs to invent a device that you can plug into
your ear or nose and
| it downloads your memory onto a stick that can be plugged
into a hard drive
| or printer for making 4x5's for $0.13!
| What is the resolution of the human eye, anyway?
Old October 9th 06, 11:35 PM posted to rec.aviation.piloting
Judah
No, I mean in MegaPixels.
"Jim Macklin" wrote in news:POzWg.1483
$XX2.194@dukeread04:
Old October 10th 06, 12:00 AM posted to rec.aviation.piloting
Peter Duniho
That depends on both your estimate of angular resolution as well as your
estimate of the high-resolution field of view. Both vary considerably.
As an example, let's say that for the purpose of your question, we consider
only the field of view attributable to the fovea (the part of the eye that
has only cones, and no rods...this is considered the limit of
"high-resolution" vision...you can see a much wider field of view than this,
but without nearly the same detail as in the center of your vision). A
quick Google search turns up estimates of foveal field of view between 4
degrees and 15 degrees. So already we have quite a discrepancy of
estimates.
If we accept the 1 minute of angle estimate for angular resolution, that
gives us between 240 and 900 units of vision across the field of view. Call
those the equivalent of pixels, and assume a perfectly circular visual
reception, and you get between 45K and 636K "pixels". So in megapixels,
that's between 0.045 and 0.636.
That said, this is a pretty simplistic analysis of the equivalent in
megapixels of human vision. Human vision is different than digital vision
in a variety of ways, and a direct mapping such as shown above is leaving
out a lot of other factors that may affect total effective resolution. But
at the very least, this gives you a ballpark minimum starting point.
Also keep in mind that a digital camera may or may not have a lens capable
of resolving in perfect detail the total resolution available on the image
detector (usually a CCD). So you may have an 8MP camera, but when you look
at an image zoomed on a computer screen at a
one-display-pixel-per-image-pixel ratio, you may find a variety of artifacts
in the digital image.
So basically, human vision may be better than the theoretically calculated
resolution, while a digital camera may have less than the theoretically
calculated resolution. It's really hard to compare in a true
apples-to-apples way.
Pete
Old October 10th 06, 01:16 AM posted to rec.aviation.piloting
Judah
"Peter Duniho" wrote in
snip
Call those the equivalent of pixels, and assume a perfectly circular
visual reception, and you get between 45K and 636K "pixels". So in
megapixels, that's between 0.045 and 0.636.
snip
calculated resolution, while a digital camera may have less than the
theoretically calculated resolution. It's really hard to compare in a
true apples-to-apples way.
So what you're basically saying is that my idea of plugging a BlueTooth
interface into one's cereberal cortex is impractical until we first come up
with a way to upgrade the eyes to a higher megapixel rating... I guess that
makes some sense - I can't really tell the difference between a 1 MP image
and an 8MP image...
Old October 10th 06, 06:14 AM posted to rec.aviation.piloting
Peter Duniho
up
No, not at all. If you come up with a 100% safe means to do that, I'll be
one of the first customers, especially if you include a "last 5 minutes"
video loop buffer. Resolution is not always the most important aspect of
photography.
So, get to work!
Old October 10th 06, 12:17 AM posted to rec.aviation.piloting
Jim Macklin
Google
Clarkvision Photography - Resolution of the Human Eye At any
one moment, you actually do not perceive that many pixels,
but your eye moves around the scene to see all the detail
you want. But the human eye ...
http://www.clarkvision.com/imagedeta...esolution.html -
12k - Cached - Similar pages
Visual Acuity and Digital Images It turns out that the human
eye only has a certain number of light detectors in it. ...
However, in digital images, the pixels or dots are square.
www.blaha.net/Main%20Visual%20Acuity.htm - 53k -
[DOC] http://clarkvision File Format: Microsoft Word - View
as HTML
The Human eye is able to function in bright sunlight
and view faint starlight, ... Visual acuity is defined as
1/a where a is the response in x/arc-minute. ...
http://www.nhn.ou.edu/~johnson/Educa...Range-2005.doc
- Similar pages
TECHNOLOGY CORNER ACUITY IN PRACTICE. A single human eye
sees roughly a 140-degree field ... Now, let's calculate the
distance between scanning line centers and pixel centers ...
http://www.tvtechnology.com/features...features.shtml
- 25k - Cached - Similar pages
Visual Acuity in Sensory Substitution for the Blind In
measuring the visual acuity of normal human vision, the eyes
move around ... with a typical horizontal resolution of 176
pixels for the PC camera input, ...
www.seeingwithsound.com/acuity.htm - Similar pages
HDTV displays: How good do they need to be? Thus, screens
don't have lines any more, only rows or columns of pixels.
.... The human visual acuity is 20/20 at any distance if the
height of the ...
broadcastengineering.com/hdtv-displays/ - 67k -
| "Jim Macklin" wrote
in news:POzWg.1483
contrast.
The Most Expensive Ironing Boards in the World... Jay Honeck Piloting 105 October 11th 06 02:18 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
