![]() Mxsmanic wrote: Mark writes: On a light twin, that second engine will have just enough power to get you to the scene of the accident. I keep reading that, but I wonder to what extent it's actually true. Apparently some twins are much more handicapped by a lost engine than others. It seems to me that if a twin is seriously crippled by the loss of an engine, it may be better to just go with a single, since the statistical probability of an engine failure is higher for a twin. On the other hand, if the twin can fly in a useful way for a time even after losing an engine, it would give you an extra margin of safety over a single. And there you have the crux of the arguments for and against twin engine piston aircraft. In general, the fatality rate for twins is higher than that of singles, until you include turboprops. In piston aircraft, the basic function of a second engine is to give you somewhat better performance at an enormous cost in fuel and safety. A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. |
cjcampbell wrote:
And there you have the crux of the arguments for and against twin engine piston aircraft. In general, the fatality rate for twins is higher than that of singles, until you include turboprops. In piston aircraft, the basic function of a second engine is to give you somewhat better performance at an enormous cost in fuel and safety. A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. It also gives you some redundancy in systems: generators, vacuum, etc... |
cjcampbell writes:
A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. Look it up on Google and you will find your answer. Don't waste our time on answers you can look up yourself. Isn't that what you told me to do???? Allen |
![]() Mxsmanic wrote: cjcampbell writes: A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. They are simple, but much less efficient than piston engines. Every teaspoon of fuel has a fixed number of calories. Efficiency is measured by what percentage of these calories is translated to thrust. The reason turbines generate so much power despite their inefficiency is that they can burn a lot more fuel even though they waste much of the energy in the fuel. The inefficiency translates into incompletely burned fuel, waste heat, exhaust, and pollution. Basically, this means that you have to burn more fuel to generate 100hp in a turbine engine than you do in a piston engine. A jet engine loses even more efficiency in the translation of hp to thrust. A turboprop is more efficient than a pure jet because of its propeller, but it still is not as efficient as a piston engine. Turbines will probably never be as efficient as piston engines. This is why gas turbine automobiles have never become popular. People don't want a car that gets less than 10mpg unless it is a Rolls Royce. Plus, acceleration is terrible. Chrysler built a batch of gas turbine concept cars back in the early '60s and lent them to ordinary consumers as a test. People hated them, not least because of the annoying, high-pitched whine. I remember seeing them at car shows back then. But, hey: it would burn anything -- gas, diesel, jet fuel, vegetable oil, even perfume (and how long will it be before the price of gas approaches that of perfume, either as fuel or otherwise -- and what is it with cars and perfume, anyway?). The reason we use jet engines is that they are inherently more powerful and they can operate at high altitudes where the efficiency penalty compared to piston engines is less. At high speeds, drag is a more important factor in fuel economy than engine efficiency, so jet airliners get their best fuel economy at high altitude. But for short hauls where it would just be a waste of fuel to climb to high altitude and descend again, a turboprop will deliver more power than a piston engine with greater fuel economy than a jet. |
cjcampbell wrote:
Mxsmanic wrote: cjcampbell writes: A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. They are simple, but much less efficient than piston engines. Plus, parts are a lot more expensive and when things go very bad, the maintenance costs are a lot more than a piston. That alone scares a lot of operators off. Ok, actually, I don't know much about turboprops, but that's the case for turbofans. |
![]() Emily wrote: cjcampbell wrote: Mxsmanic wrote: cjcampbell writes: A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. They are simple, but much less efficient than piston engines. Plus, parts are a lot more expensive and when things go very bad, the maintenance costs are a lot more than a piston. That alone scares a lot of operators off. Ok, actually, I don't know much about turboprops, but that's the case for turbofans. From a maintenance standpoint, just think of a turboprop as being a turbofan with a lot less blades. |
cjcampbell wrote:
Emily wrote: cjcampbell wrote: Mxsmanic wrote: cjcampbell writes: A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. They are simple, but much less efficient than piston engines. Plus, parts are a lot more expensive and when things go very bad, the maintenance costs are a lot more than a piston. That alone scares a lot of operators off. Ok, actually, I don't know much about turboprops, but that's the case for turbofans. From a maintenance standpoint, just think of a turboprop as being a turbofan with a lot less blades. LOL...yeah, the whole gas generator and power tubine thing seems a little to complex. I'm sure at some point I understand it, but you forget what you don't use. |
All internal combustion engines work the same. A turbine
just does it as a series of continuous events in different sections of the engine and a piston engine does one at a time so power is produced only 1/4 of the time in a 4 cycle and 1/2 the time in a two cycle. I'm going to print some T-shirts... "SUCK SQUEEZE BANK and BLOW Get your mind out of the gutter, it is an engine" The P&W PT6 is perhaps the most popular turboprop. It uses air coupling between the power and reduction gear section. Makes it better in many ways, but there is a loss of efficiency. "Emily" wrote in message ... | cjcampbell wrote: | Emily wrote: | cjcampbell wrote: | Mxsmanic wrote: | cjcampbell writes: | | A turborprop | increases safety, but now you are talking real money, both in | acquisition cost and in fuel and maintenance. | Why are turboprops so much more expensive? I thought gas turbines | were supposed to be simpler and more efficient. | They are simple, but much less efficient than piston engines. | Plus, parts are a lot more expensive and when things go very bad, the | maintenance costs are a lot more than a piston. That alone scares a lot | of operators off. | | Ok, actually, I don't know much about turboprops, but that's the case | for turbofans. | | From a maintenance standpoint, just think of a turboprop as being a | turbofan with a lot less blades. | | LOL...yeah, the whole gas generator and power tubine thing seems a | little to complex. I'm sure at some point I understand it, but you | forget what you don't use. |
cjcampbell writes:
The reason we use jet engines is that they are inherently more powerful and they can operate at high altitudes where the efficiency penalty compared to piston engines is less. At high speeds, drag is a more important factor in fuel economy than engine efficiency, so jet airliners get their best fuel economy at high altitude. But for short hauls where it would just be a waste of fuel to climb to high altitude and descend again, a turboprop will deliver more power than a piston engine with greater fuel economy than a jet. There are still the questions of simplicity and reliability, which I thought were both higher for gas turbines. They are certainly more reliable; and I should think they'd be simpler, too. -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
