"gman" wrote in message
ups.com... The consensus around here is that as long as the engines are blessed by the mechanics and checked for compression, one can exceed the recommended TBO sometimes by a factor of 2x. The Oct '06 edition of "Light Plane Maintenance" fielded a question on exceeding TBO with a Lycoming O-320 in a Cessna 172 (you didn't say what engine you have). The engine burns 1qt/8 hours and the compressions are all in the low 70s. The owner recently did a valve wobble check. Biggest concern: exhaust valve break up, which apparently nearly always happens in flight, but which is usually preceded by said valve getting burnt, then getting hot, and then failing. Recommendation: Continue flying until engine gives a reason for overhaul. Increase monitoring, especially by doing frequent compression checks (25 hours) and attention to oil (filter/screen + oil analysis). Compression check verifies both cylinder & valves not seating properly. Investigate if any cylinder showing compression in the low 60s. |
Recommended source for 4130 sheet and tubing? | Michael Horowitz | Restoration | 3 | April 16th 06 07:23 PM |
Anywhere recommended near Rochester MN? | Dave | General Aviation | 0 | April 8th 04 11:48 AM |
Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 7th 04 03:46 PM |
Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 1st 04 05:18 PM |
