Since the "MDA rule" only refers to MDA, and the MDA only exists on
the final segment, I think that if you were operating below an altitude specified for some other segment, and had some kind of problem as a result, a case could be made against you if there were an enforcement action of some kind. I'm 80% of the way through my IFR so I must be right. ;-) From my understanding is that this is correct. Think about it this way, if you were 30 miles out and you had the runway environment in sight, a normal descent rate can be made and flight visibility was met, can you descend below MEA/MDA? of course not. The MDA rule is for after the FAF so you can land otherwise you can simply choose your altitude at any point of the approach claiming all 3 items were met. the other big thing people are missing is the approach is not only to keep you safe but also the controller will expect you to be along the published route. A controller can certainly vector a VFR or IFR plane below you.....published minimum for one of the step downs is say 3000 AGL giving enough clearance. If you are lower, something bad could happen. This is similar to what happened to the actor (?) a few weeks ago (If I recall correctly). In that case I believe the actor misunderstood or incorrectly determined he was cleared lower when he was not. Gerald |
On Wed, 05 Jan 2005 02:59:56 GMT, "G. Sylvester"
wrote: I'm 80% of the way through my IFR so I must be right. ;-) From my understanding is that this is correct. Think about it this way, if you were 30 miles out and you had the runway environment in sight, a normal descent rate can be made and flight visibility was met, can you descend below MEA/MDA? of course not. The MDA rule is for after the FAF so you can land otherwise you can simply choose your altitude at any point of the approach claiming all 3 items were met. Although we've gotten a bit afield, in the OP's example he was considering descent at a point within the final segment (i.e. between the FAF and the MAP). the other big thing people are missing is the approach is not only to keep you safe but also the controller will expect you to be along the published route. A controller can certainly vector a VFR or IFR plane below you.....published minimum for one of the step downs is say 3000 AGL giving enough clearance. If you are lower, something bad could happen. This is similar to what happened to the actor (?) a few weeks ago (If I recall correctly). In that case I believe the actor misunderstood or incorrectly determined he was cleared lower when he was not. Clearly bad things can happen if you are below the charted altitude for a segment of the approach. However, the controller will not vector an aircraft below you once you have been cleared for the approach and are past the IAF. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "G. Sylvester" wrote: Since the "MDA rule" only refers to MDA, and the MDA only exists on the final segment, I think that if you were operating below an altitude specified for some other segment, and had some kind of problem as a result, a case could be made against you if there were an enforcement action of some kind. I'm 80% of the way through my IFR so I must be right. ;-) From my understanding is that this is correct. Think about it this way, if you were 30 miles out and you had the runway environment in sight, a normal descent rate can be made and flight visibility was met, can you descend below MEA/MDA? of course not. The MDA rule is for after the FAF so you can land otherwise you can simply choose your altitude at any point of the approach claiming all 3 items were met. the other big thing people are missing is the approach is not only to keep you safe but also the controller will expect you to be along the published route. A controller can certainly vector a VFR or IFR plane below you.....published minimum for one of the step downs is say 3000 AGL giving enough clearance. If you are lower, something bad could happen. This is similar to what happened to the actor (?) a few weeks ago (If I recall correctly). In that case I believe the actor misunderstood or incorrectly determined he was cleared lower when he was not. Gerald The controller cannot vector someone below you unless they are at, or above, the MVA. This was about a stepdown fix two miles from the runway. 30 miles out is an entirely different matter. |
Are pilots really good or just lucky??? | Icebound | Instrument Flight Rules | 68 | December 9th 04 01:53 PM |
Canadian departure minimums? | Derrick Early | Instrument Flight Rules | 3 | August 9th 04 01:43 PM |
Can ATC assign an airway if filed direct? | Andrew Sarangan | Instrument Flight Rules | 26 | March 4th 04 12:23 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 07:46 AM |
