How are your engine monitor probe leads and wiring harnesses secured? Adel
clamps on the rocker box covers? Tie wrapped to your ignition leads? Tie wrapped to the intake tubes? Adel clamps to the lower case/sump bolts? Ours is a mix of both types, where appropriate. And, just like TC says, the zip ties have grown brittle and broken in the areas that get extremely hot. I've replaced about half of them, and the analyzer has only been in the plane four years. I may have to buy some of that waxed lace stuff. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Ahead of the firewall, when I do use zip ties, I use the high temp 205
degree C Mil spec tie wraps. They aren't cheap but seem to last quite a bit longer than the generic Menards nylon. Jim "Jay Honeck" wrote in message oups.com... How are your engine monitor probe leads and wiring harnesses secured? Adel clamps on the rocker box covers? Tie wrapped to your ignition leads? Tie wrapped to the intake tubes? Adel clamps to the lower case/sump bolts? Ours is a mix of both types, where appropriate. And, just like TC says, the zip ties have grown brittle and broken in the areas that get extremely hot. I've replaced about half of them, and the analyzer has only been in the plane four years. I may have to buy some of that waxed lace stuff. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 03:11 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
