OK......since it has a "Catch" here's the answer
Old October 11th 06, 09:54 PM posted to rec.aviation.piloting
Peter Duniho
Default OK......since it has a "Catch" here's the answer
"Morgans" wrote in message
The answer to what?
To what light twin could take off on one engine. (a different thread)
Kinda cheating, having a huge runway, like a lake! g
Ahh...thanks. I'd killed that thread already. Guess I missed the question.
Though, seems to me that with a sufficiently long runway, any light twin
could take off on one engine, assuming the runway elevation is reasonably
below the single-engine service ceiling. If you have enough thrust to
maintain altitude, you have enough thrust to takeoff.
You do, of course, need sufficient directional control, but I'd guess that
between the nosewheel, some rudder effectiveness, and even some judicious
braking (even if it does lengthen the takeoff run even further), this is
just a matter of pilot technique, not of whether it can be done at all.
I guess I'm surprised this was questioned by anyone (except possibly our
resident know-nothing-question-everything, of course), and especially to the
extent to require a new thread.
My apologies if I've just restarted the debate. Just tell me to go back and
read the original thread if I'm opening the same can of worms again.
Pete
Old October 12th 06, 01:38 AM posted to rec.aviation.piloting
Morgans[_2_]
braking (even if it does lengthen the takeoff run even further), this is just
It seems as though nobody could argue against the point that with a dead engine,
most light twins can not even MOVE in a straight line, from a standing start. I
guess since most engines are outboard from the wheels, even brakes are no good
at all, and that nosewheels will just slide sideways. Of course, rudders are no
good at that speed.
Jim in NC
Old October 12th 06, 03:00 AM posted to rec.aviation.piloting
Peter Duniho
dead engine, most light twins can not even MOVE in a straight line,
Having seen plenty of twins (big and small) taxi around with just one engine
running, I'd say it'd be pretty easy to argue against that claim. The proof
is in the pudding.
Old October 12th 06, 04:55 PM posted to rec.aviation.piloting
Kris Kortokrax
that between the nosewheel, some rudder effectiveness, and even some
judicious braking (even if it does lengthen the takeoff run even
further), this is just a matter of pilot technique, not of whether it
can be done at all.
engine, most light twins can not even MOVE in a straight line, from a
standing start. I guess since most engines are outboard from the
wheels, even brakes are no good at all, and that nosewheels will just
slide sideways. Of course, rudders are no good at that speed.
I seem to remember that in his book "Logging Flight Time", Bill Kershner
described a demonstration flight he did for the Air Force in an Aztec,
where he took off, flew through some maneuvers and landed with one
engine shut down.
Kris
Old October 15th 06, 02:10 AM posted to rec.aviation.piloting
Capt.Doug
engine,
start. I
good
are no
good at that speed.
Navajos' nose wheel steering is connected by rods to the rudder pedals. It
is easy to take-off on one engine. Free castoring nosewheels can be a bitch
if not impossible. AeroCommanders and C-310s can be done. The secret is that
as you speed up, the circle gets bigger and bigger.
D.
A New Threat to The USA, Iranian F-14 Tomcats? Answer it ... Amir - Iranian F-4 pilot Naval Aviation 13 September 28th 06 11:34 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Answer on CEF ILS RWY 23 questions Paul Tomblin Instrument Flight Rules 21 October 17th 04 04:18 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
