NDB Bearing Intercepts & Rotatable Compass Card ADFs
Old October 11th 06, 10:25 PM posted to rec.aviation.student,rec.aviation.ifr
Bob Gardner
Default NDB Bearing Intercepts & Rotatable Compass Card ADFs
Thks is an idea I disagree with. The rotatable azimuth is there for a reason
and should be used. The problem comes when the instrument student tries to
adjust the bezel for every heading change. A better method is to estimate
how much heading change into the wind is necessary in order to offset wind
drift and set the bezel to that heading...maybe five to ten degrees away
from the published course...and then work at maintaining that estimated
heading until it is proven wrong by moving either further into the wind or
back toward the nose. Whatever. Change the bezel a couple of degrees in the
necessary direction and go back to work on maintaining the heading using the
DG. Shouldn't have to touch the rotatable azimuth more than a couple of
times during an approach, if you are any good at guessing crosswind
component.
Bob Gardner
"Gary Drescher" wrote in message
OBI and the ADF
Er, make that CDI.
Old October 12th 06, 05:04 PM posted to rec.aviation.student,rec.aviation.ifr
Sam Spade
component.
Better yet, relegate ADF to the museum of 20th Century aviation
artifacts. ;-)
Old October 12th 06, 11:06 PM posted to rec.aviation.student,rec.aviation.ifr
Jim Macklin
Even better, get an RMI either mechanical or electronic.
"Sam Spade" wrote in message
news:iItXg.32428$tO5.10002@fed1read10...
ten degrees away
that estimated
than a couple of
guessing crosswind
| component.
aviation
| artifacts. ;-)
For Sale Dittel Radio, Vertical Compass Card [email protected] Soaring 0 May 4th 06 10:23 PM
Vertical Card Compass Mystery Rosspilot Owning 3 November 3rd 04 06:01 PM
Graphics Jim Chambers Simulators 14 April 22nd 04 03:29 AM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
