Bob Gardner wrote:
Thks is an idea I disagree with. The rotatable azimuth is there for a reason and should be used. The problem comes when the instrument student tries to adjust the bezel for every heading change. A better method is to estimate how much heading change into the wind is necessary in order to offset wind drift and set the bezel to that heading...maybe five to ten degrees away from the published course...and then work at maintaining that estimated heading until it is proven wrong by moving either further into the wind or back toward the nose. Whatever. Change the bezel a couple of degrees in the necessary direction and go back to work on maintaining the heading using the DG. Shouldn't have to touch the rotatable azimuth more than a couple of times during an approach, if you are any good at guessing crosswind component. Better yet, relegate ADF to the museum of 20th Century aviation artifacts. ;-) |
Even better, get an RMI either mechanical or electronic.
"Sam Spade" wrote in message news:iItXg.32428$tO5.10002@fed1read10... | Bob Gardner wrote: | Thks is an idea I disagree with. The rotatable azimuth is there for a reason | and should be used. The problem comes when the instrument student tries to | adjust the bezel for every heading change. A better method is to estimate | how much heading change into the wind is necessary in order to offset wind | drift and set the bezel to that heading...maybe five to ten degrees away | from the published course...and then work at maintaining that estimated | heading until it is proven wrong by moving either further into the wind or | back toward the nose. Whatever. Change the bezel a couple of degrees in the | necessary direction and go back to work on maintaining the heading using the | DG. Shouldn't have to touch the rotatable azimuth more than a couple of | times during an approach, if you are any good at guessing crosswind | component. | | Better yet, relegate ADF to the museum of 20th Century aviation | artifacts. ;-) |
For Sale Dittel Radio, Vertical Compass Card | [email protected] | Soaring | 0 | May 4th 06 10:23 PM |
Vertical Card Compass Mystery | Rosspilot | Owning | 3 | November 3rd 04 06:01 PM |
Graphics | Jim Chambers | Simulators | 14 | April 22nd 04 03:29 AM |
Strange compass behavior | me | Owning | 10 | February 14th 04 04:24 AM |
