PCAS - Portable Collision Avoidance System
Old October 13th 06, 10:08 PM posted to rec.aviation.soaring
Mike Schumann
Default PCAS - Portable Collision Avoidance System
That is NOT correct. TCAS was specifically designed to provide evasive
maneuver info for airliners that are on a collision course with GA aircraft.
However, the GA aircraft needs a Mode C Transponder (and it needs to be
turned on).
Mike Schumann
"Marc Ramsey" wrote in message
http://www.zaonflight.com/mrx.html
If you think that an airliner in going to spot you just because
you have a transponder, is a very false security.
I fly a Boeing jet for a living and at times it is very hard to see
another jet that ATC and TCAS alerted us to.
But doesn't TCAS gives you resolution without the need to spot the
threat? I was under the impression that it does.
Only if the threat is also equipped with TCAS...
Marc
Old October 13th 06, 10:24 PM posted to rec.aviation.soaring
Marc Ramsey
turned on).
You are correct, I was confusing limitations of TCAS I with TCAS II...
Marc
Collision Avoidance and ATC Bubba Soaring 5 September 1st 06 04:31 AM
Getting the MOCA Dan Instrument Flight Rules 59 July 3rd 06 01:43 AM
Collision Avoidance Systems [email protected] Products 0 May 21st 06 10:15 PM
WANTED: WTB - Portable Ox system ecktoeman Aviation Marketplace 0 November 26th 03 01:18 AM
