![]() This isn't an IFR topic, but I figure there might be a heavy iron pilot or two reading this. There's a thread on the FS group about landing 747/777 class airplanes. I've read that they typically kick out the crab right before touchdown much as some lighter airplane pilots do. Slips are out because of the risk of dragging an engine. However, a number of folks there claim that the airliners are simply landed with the crab angle held during the approach. I know that the B-52 has gear designed to align for a crab landing and I think one or two models of the 747 may have this as well, but everything I've read always said that standard procedure with airliners was to remove the crab before touchdown. And this is certainly what has been done on almost all airline flights I've made. Any '47 or '77 or similar pilots here who can comment on the generally accepted technique for crosswing landings in the heavy machines? I searched around this evening and found a number of sources that claimed both methods are the "right" method, but no source that I'd consider authoritative. Matt |
I can't speak to the 747 or 777, but I can the 767 and L-1011. There is
always controversy about it, but the truth is in watching the autopilot do an auto-land. It's all crab until about 150 feet, HAT, where the autopilot goes into align mode; that is it transitions from crab to wing down into the wind with a slight amount of upwind rudder. This last throughout the flare to touchdown. Good pilots manually land those models using the same technique. So long as the certificated cross-wind limits are observed and the technique is done correctly you won't scrape an engine. The most critical airplane with which I was familiar for scrapping an outboard engine was the 707. There, you had to observe a 5-degree bank angle limit, so in a 30 knot cross-wind some combination slip and crab became necessary. If it is just crab it is really tough to "kick it out" at the last moment without it becoming a spectacular event. Matt Whiting wrote: This isn't an IFR topic, but I figure there might be a heavy iron pilot or two reading this. There's a thread on the FS group about landing 747/777 class airplanes. I've read that they typically kick out the crab right before touchdown much as some lighter airplane pilots do. Slips are out because of the risk of dragging an engine. However, a number of folks there claim that the airliners are simply landed with the crab angle held during the approach. I know that the B-52 has gear designed to align for a crab landing and I think one or two models of the 747 may have this as well, but everything I've read always said that standard procedure with airliners was to remove the crab before touchdown. And this is certainly what has been done on almost all airline flights I've made. Any '47 or '77 or similar pilots here who can comment on the generally accepted technique for crosswing landings in the heavy machines? I searched around this evening and found a number of sources that claimed both methods are the "right" method, but no source that I'd consider authoritative. Matt |
![]() Matt Whiting wrote: Did you ever intentionally land with the crab angle intact? This is what is advocated by a gentleman on the MSFS group who says he is a retired "heavy" captain. I saw it done once in a 707 and I thought the landing gear was going to collapse. |
Matt Whiting wrote
Did you ever intentionally land with the crab angle intact? YES This is what is advocated by a gentleman on the MSFS group who says he is a retired "heavy" captain. Quoting from my PanAm B-707 Flight Manual " CROSSWIND LANDINGS Make a normal approach. Maintain runway alignment by crabbing. Before touchdown, gradually remove as much of the crab as possible with rudder. It may be necessary to land with some crab angle if the crosswind is high. This presents no problem if the angle is not excessive and the flightpath is aligned with the runway. CAUTION Touchdown with a large crab angle and the wings level may result in a rapid rising of the upwind wing and may cause an engine nacelle to drag on the runway. Bob Moore PanAm (retired) 17 years in the grand old 707 6 years as 707 instructor/check airman |
Matt Whiting wrote:
wrote: Matt Whiting wrote: Did you ever intentionally land with the crab angle intact? This is what is advocated by a gentleman on the MSFS group who says he is a retired "heavy" captain. I saw it done once in a 707 and I thought the landing gear was going to collapse. He posted a bunch of references daying that landing with crab was SOP for airlines and the military. I find it hard to believe and it contradicts most everything I've read on the subject, but I don't fly heavies so all I know is what I read. Typo: I meant "saying." His references appeared completely legitimate so it appears that landing in a crab is acceptable technique in at least some airplanes (he referenced the F-16 and a couple of others). Matt |
![]() "Matt Whiting" wrote in message ... wrote: Matt Whiting wrote: Did you ever intentionally land with the crab angle intact? This is what is advocated by a gentleman on the MSFS group who says he is a retired "heavy" captain. I saw it done once in a 707 and I thought the landing gear was going to collapse. He posted a bunch of references daying that landing with crab was SOP for airlines and the military. I find it hard to believe and it contradicts most everything I've read on the subject, but I don't fly heavies so all I know is what I read. Matt I flew, as a qualified pilot/instructor pilot, the T-38, B-52 and B-1B in the AF. The T-38, hardly a heavy, was landed fully crabbed into the wind. As has already been mentioned, the gear was turned in the B-52 to align with the rwy so that effectively had the aircraft crabbed into the wind, and in the B-1B, you crabbed until short final, approaching the over run, where you aligned yourself with the rwy hdg in a wing low attitude and landed on the upwind truck, just like in a 172. JB |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
RAH'er has forced landing | Ron Wanttaja | Home Built | 33 | December 24th 04 12:58 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 06:51 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
