Recently, Mxsmanic posted:
writes: Just do what you'd do in real life - slow down. When you find yourself closely following traffic to the runway, you can create more time between you and the guy in front by slowing down. Of course, this may cause trouble for the guy behind you, but that's his problem. You can also fly S-turns to create additional spacing. In the sim, the problem is usually that the plane in front of me lingers on the runway after landing. Then the controller tells me to go around. I'm not given the option of refusing (although sometimes I just ignore the controller and continue). Talking about --how did you put it -- "...local pilots doing foolish things...", this should be pretty close to the top of your list. And, it will get you into an interesting but short discussion with the FAA, should you survive that decision. Neil |
Neil Gould writes:
Talking about --how did you put it -- "...local pilots doing foolish things...", this should be pretty close to the top of your list. And, it will get you into an interesting but short discussion with the FAA, should you survive that decision. Sure ... in a real aircraft. But in simulation it's okay (as long as you realize that it's only acceptable in simulation). I figure the ATC has way too many aircraft going around, so my revenge on the simulator is simply to ignore the incompetent controller and continue. Yesterday I took off into a 110 kt headwind blowing precisely down the runway towards me. I left the ground within a few seconds, drifting gently backwards, then forwards. Landing was easy, with a ground speed of almost zero. That experiment would not be possible or practical in real life. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Neil Gould writes: Talking about --how did you put it -- "...local pilots doing foolish things...", this should be pretty close to the top of your list. And, it will get you into an interesting but short discussion with the FAA, should you survive that decision. Sure ... in a real aircraft. But in simulation it's okay (as long as you realize that it's only acceptable in simulation). I figure the ATC has way too many aircraft going around, so my revenge on the simulator is simply to ignore the incompetent controller and continue. And, it's precisely that attitude that is the focus of the point I was making. As PIC, you have no idea of the "competence" of the controller, or the basis for instructions that you receive. Unless you are unable to execute those instructions, you are expected to do so. If you are unable to execute a go-around, you should have notified ATC about it well ahead of time so that they could plan accordingly. So, you've made a number of bad decisions based on bad assumptions and then executed a maneuver that could get your license pulled, should you survive it. You are missing the purpose of even MSFS in this case, and that's not too impressive. Neil |
Neil Gould writes:
If you are unable to execute a go-around, you should have notified ATC about it well ahead of time so that they could plan accordingly. The simulator does not give me the option of refusing. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Neil Gould writes: If you are unable to execute a go-around, you should have notified ATC about it well ahead of time so that they could plan accordingly. The simulator does not give me the option of refusing. It also doesn't make the plane unable to execute the instruction. Ergo, you should have gone around. Neil |
Neil Gould writes:
It also doesn't make the plane unable to execute the instruction. Ergo, you should have gone around. Instructions are flexible in simulation. If I followed all instructions slavishly, I'd occasionally be stuck for eternity on the ramp because the simulator doesn't give me the option of asking to taxi and take off. -- Transpose mxsmanic and gmail to reach me by e-mail. |
