"RK Henry" wrote in message
... Actually the FAA means , in the paragraph you cited, that "operate" means use an airplane in a business or otherwise have the control of the airplane. It does not mean that the engine is running. It means all that and more. It's an all-purpose definition intended to be plugged into wherever the term is found in the regulations. Does that mean that regulations that use the word "operate" do not apply to gliders? It may be that some aircraft cannot be operated without an engine running, but a) an aircraft with an engine can have that engine running without the airplane being "operated", and b) some aircraft can be operated without any engine, running or otherwise. It may be a fine line, but the line is there and I see no reason to infer from the regulation that the starting of an engine necessarily has anything to do with the operation of anticollision lights. Pete |
Turning beacons on before start was part of "Operation
Lights ON" as an advisory for safety reasons. I have no problem with that as long as it does not cause harm to the airplane. At night is required to turn the NAV lights on. AIM 4-3-23. Use of Aircraft Lights a. Aircraft position lights are required to be lighted on aircraft operated on the surface and in flight from sunset to sunrise. In addition, aircraft equipped with an anti-collision light system are required to operate that light system during all types of operations (day and night). However, during any adverse meteorological conditions, the pilot-in-command may determine that the anti-collision lights should be turned off when their light output would constitute a hazard to safety (14 CFR Section 91.209). Supplementary strobe lights should be turned off on the ground when they adversely affect ground personnel or other pilots, and in flight when there are adverse reflection from clouds. b. An aircraft anti-collision light system can use one or more rotating beacons and/or strobe lights, be colored either red or white, and have different (higher than minimum) intensities when compared to other aircraft. Many aircraft have both a rotating beacon and a strobe light system. c. The FAA has a voluntary pilot safety program, Operation Lights On, to enhance the see-and-avoid concept. Pilots are encouraged to turn on their landing lights during takeoff; i.e., either after takeoff clearance has been received or when beginning takeoff roll. Pilots are further encouraged to turn on their landing lights when operating below 10,000 feet, day or night, especially when operating within 10 miles of any airport, or in conditions of reduced visibility and in areas where flocks of birds may be expected, i.e., coastal areas, lake areas, around refuse dumps, etc. Although turning on aircraft lights does enhance the see-and-avoid concept, pilots should not become complacent about keeping a sharp lookout for other aircraft. Not all aircraft are equipped with lights and some pilots may not have their lights turned on. Aircraft manufacturer's recommendations for operation of landing lights and electrical systems should be observed. d. Prop and jet blast forces generated by large aircraft have overturned or damaged several smaller aircraft taxiing behind them. To avoid similar results, and in the interest of preventing upsets and injuries to ground personnel from such forces, the FAA recommends that air carriers and commercial operators turn on their rotating beacons anytime their aircraft engines are in operation. General aviation pilots using rotating beacon equipped aircraft are also encouraged to participate in this program which is designed to alert others to the potential hazard. Since this is a voluntary program, exercise caution and do not rely solely on the rotating beacon as an indication that aircraft engines are in operation. e. At the discretion of the pilot-in-command turn on all external illumination, including landing lights, when taxiing on, across, or holding in position on any runway. This increases the conspicuity of the aircraft to controllers and other pilots approaching to land, taxiing, or crossing the runway. Pilots should comply with any equipment operating limitations and consider the effects of landing and strobe lights on other aircraft in their vicinity. When cleared for takeoff pilots should turn on any remaining exterior lights. AC 91.73 (2) Because adherence to the guidelines in this AC are voluntary and aircraft equipment varies, flightcrews are cautioned not to rely solely on the status of an aircraft's lights to determine the intentions of the flightcrew of the other aircraft. Additionally, flightcrews must remember to comply with operating limitations on the aircraft's lighting systems. b. Exterior Lights. To the extent possible and consistent with aircraft equipage, operating limitations, and flightcrew procedures, illuminate exterior lights as follows: (1) Engines running. Turn on the rotating beacon whenever an engine is running. (2) Taxiing. Prior to commencing taxi, turn on navigation, position, anti-collision, and logo lights. Strobe lights should not be illuminated during taxi if they will adversely affect the vision of other pilots or ground personnel. (3) Crossing a runway. All exterior lights should be illuminated when crossing a runway. (4) Entering the departure runway for takeoff. When entering a runway to takeoff, or when taxiing into position and holding for takeoff, illuminate one or more landing lights and all other exterior lights. Strobe lights should not be illuminated if they will adversely affect the vision of other pilots. (5) Takeoff. Turn on all remaining landing lights when takeoff clearance is received or when commencing takeoff roll at an airport without an operating control tower. 8. SUMMARY. Taxi operations require constant vigilance by the entire flightcrew, not just the pilot taxiing the aircraft. The flightcrew needs to be continually aware of the movement and location of other aircraft and ground vehicles on the airport movement area. Taxi operations require the same planning, coordination, and proper execution, as do the other phases of flight operations. Safe aircraft operations can be accomplished and incidents eliminated if the flightcrew is properly trained and correctly accomplishes standard taxi operating procedures and practices. /s/ Nicholas A. Sabatini Director, Flight Standards Service "RK Henry" wrote in message ... | It means all that and more. It's an all-purpose definition intended to | be plugged into wherever the term is found in the regulations. | | I found a source on AOPA's site. I won't reproduce it here, but AOPA | members can search for it as article 352. It says that the pilot must | turn on the anti-collision lights whenever he "operates" [their | quotes] the aircraft, which means every time he starts the engine. I | consider that a fairly authoritative source, though not as | authoritative as the FAA, of course. | | RK Henry | | On Sat, 14 Oct 2006 19:09:14 -0500, "Jim Macklin" | wrote: | | Actually the FAA means , in the paragraph you cited, that | "operate" means use an airplane in a business or otherwise | have the control of the airplane. It does not mean that the | engine is running. | | | "RK Henry" wrote in message | .. . | | On Sat, 14 Oct 2006 20:52:59 +0200, Mxsmanic | | | wrote: | | | | RK Henry writes: | | | | Yes it does. In the excerpt here, "Operate" means | running the engines. | | | | According to whom? | | | | 1. In FARs part 1.1, Definitions, "Operate" is defined: | | | | "Operate, with respect to aircraft, means use, cause to | use or | | authorize to use aircraft, for the purpose (except as | provided in | | §91.13 of this chapter) of air navigation including the | piloting of | | aircraft, with or without the right of legal control (as | owner, | | lessee, or otherwise)." | | | | If you're planning on using the airplane for flying, I'd | interpret | | that as beginning with the moment you turn the key 'til | the airplane | | is back in the hangar. I suppose it could exclude running | the engine | | at the shop, since that's not for the purpose of air | navigation, but | | the mechanics usually turn on the beacon too. | | | | 2. The mention in the AIM about lights isn't regulatory, | but it may as | | well be. It's good operating practice, and a pilot | ignoring good | | operating practice could conceivably be caught by the | catch-all | | regulation, FAR 91.13, Careless or reckless operation. | Especially if | | someone got hurt. And of course, none of us wants anyone | to get hurt. | | | | Running the anti-collision system is low-cost insurance. | Except for | | cases like not operating strobes around people, it's | better to just go | | ahead and use it. It could save someone's life. | | | | RK Henry | |
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
Landing lights | Robert Barker | Owning | 20 | May 11th 06 02:33 AM |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 05:18 AM |
