Garmin to Ipaq cable wiring ?
Old October 15th 06, 02:12 PM posted to rec.aviation.soaring
Default Garmin to Ipaq cable wiring ?
Marc,
I also believe the power line in the USB is 5V and your Garmin requires 12
V. So you need some kind of a voltage regulator to drop the voltage from 12
to 5 (12 will fry your PDA.)
HP-14 "6F"
"Bernie Baer" wrote in message
Gotcha, thanks Marc!
Old October 15th 06, 04:15 PM posted to rec.aviation.soaring
Marc Ramsey
Wayne Paul wrote:
Marc,
Actually, the GPS 12 that the original poster mentioned is one of the
odd Garmins that needs a 5 to 8 VDC supply. I'm not sure how well it
will work, but if he is looking to supply power externally (which he may
not be), 5V may work for both...
Marc
Old October 15th 06, 04:34 PM posted to rec.aviation.soaring
Marc Ramsey
And, just to confuse things further, the "GPS 12" is different from the
"GPS 12XL" and "GPS 12MAP", which both take 10 to 32 VDC externally...
Marc
Old October 15th 06, 09:14 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Wayne Paul wrote:
Marc,
If you're feeling handy with a soldering iron and want to save a little
cash, go out and buy the cable used to power an iPAQ from a car cigar
lighter socket. They are cheap and the plug on the cigar lighter end
contains a very small switch-mode 5v power supply. You can also find
iPAQ cable with 12v ans serial date lines in it, so you only need one
cable and plug on the iPAQ.
It may be a good idea to put the PSU in a metal box and add ferrite
suppressors to the cables connected to it because some switch mode PSUs
radiate RF like crazy.
I use exactly this setup, but the box is bigger: it also holds the
interconnect wiring to feed GPS data to my iPAQ, SDI C4 and EW logger as
well as distributing 12v to the GPS, logger and C4. All connections to
the box are D-9 connectors apart from 12v in, which is an XLR chassis
plug to match the glider's power cable. This way I can also plug a gel
cell directly into the interconnect box for bench testing at home.
The result is a neater setup behind the panel because there's just one
cable between the box and each instrument apart from the C4, which
requires a separate power cable.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
PIREP: Garmin GMA340 impedance-matching audio cable Peter R. Owning 5 June 15th 06 02:30 PM
LX20 + Ipaq wiring Bruce Soaring 2 February 4th 06 10:40 PM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
