Wade Hasbrouck writes:
"The general rule I was taught for the 172 is, provided you haven't 'creeped in on your downwind', once the landing traffice passes your wing tip, you can begin your turn to BASE, and it works out just about right..." Ah, now I am far less confused! Now, how are you looking at the traffic when you try to check if it has passed your wingtip? Kind of hard to see landing traffic pass your wingtip while ON base, and if you did, that would probably be a big indication that you just overshot your turn to final... :-) I'm very good at undershooting and overshooting final (albeit in a flip-of-the-coin sort of way). I only have difficulty aligning with the runway. And for some reason, I always seem to drift slightly left just as I'm coming up on decision height. I don't know what does this. The engines are usually near idle, so it doesn't seem like it'd be a sudden surge of torque or anything. And it seems improbable that the surface winds are _always_ blowing to the left. -- Transpose mxsmanic and gmail to reach me by e-mail. |
----- Original Message -----
From: "Mxsmanic" Now, how are you looking at the traffic when you try to check if it has passed your wingtip? You look out the window. The side window is most useful for this. Pretty obvious. He will be lower than you and in a high wing aircraft like the 172 you can see the traffic and the wing at the same time. Haven't flown a low wing, but would imagine you would do something similar like, "watch the traffic, and the wing will 'hide' the traffic, and then when the traffic is past your wingtip it the traffic will be visible again... And for some reason, I always seem to drift slightly left just as I'm coming up on decision height. I don't know what does this. The engines are usually near idle, so it doesn't seem like it'd be a sudden surge of torque or anything. And it seems improbable that the surface winds are _always_ blowing to the left. It has been several months since I messed around with Flight Sim, but I haven't ever really noticed this, so I can't really comment on what is going on. The winds due depend on if you are using the "real weather" or not... Can't comment on anything more than 172. |
It has been several months since I messed around with Flight Sim, but I haven't ever really noticed this, so I can't really comment on what is going on. The winds due depend on if you are using the "real weather" or not... Can't comment on anything more than 172. I think the sim is accurately simulating something, I just don't know what it is. Maybe I just have more of a tendency to overshoot than to undershoot. Still, it seems that I drift sometimes even after I am perfectly aligned. For what it's worth, I actually did a go-around and flew the pattern again this evening (or afternoon, in the simulator world), while landing at KPHX. I managed to hold altitude relatively well (if I understand correctly, 1000' AGL is the usual position). Turns were okay. No help from autopilot. The weather was very nice, though, which made things easier. And I know KPHX and Phoenix very well. When I saw three aircraft approaching as I turned to base I knew that ATC was going to shaft me again, but I figured I could use the practice. -- Transpose mxsmanic and gmail to reach me by e-mail. |
