Spin training
Old October 16th 06, 01:50 AM posted to rec.aviation.piloting
Viperdoc[_1_]
Default Spin training
Beggs-Mueller does not work for all planes (although it does for Pitts'),
and some pilots do not necessarily believe in letting go of the stick for a
recovery, preferring to "fly" out of the spin.
Old October 16th 06, 02:20 AM posted to rec.aviation.piloting
john smith
That's true, but shouldn't it at least be taught so that the student
fully understands spin recovery?
Old October 16th 06, 02:26 AM posted to rec.aviation.piloting
Viperdoc[_1_]
Probably, but it might fall into more advanced lessons, like inverted spins,
flat, crossover, etc. A single flight with a spin demo does not make most
pilots capable of recovery from inadvertent spins.
Old October 16th 06, 03:11 AM posted to rec.aviation.piloting
Peter Dohm
news
On Sun, 15 Oct 2006 16:23:36 -0400, Stubby
I just got back from my spin training for my CFI....
Yup. Should be a requirement before PPL.
I believe it was required long ago, perhaps 30 years. I had a bit of
spin work in the glider. It might be required. It was fun!
Yeah, was eliminated in the late '60s, I think. Basic reason, IIRC, is
that the
number of casualties that occurred during training were thought to be
about
equal to the additional spin fatalities if training WEREN'T required.
Since
most stall/spin accidents occur at very low altitudes (the base-to-final
turn,
usually) the FAA decided to emphasize stall recognition/avoidance,
instead.
True "spin" accidents (those that occur at high enough altitudes to
recover and
not associated with any physical problem with the airplane) are quite
rare.
Canada still requires spin training, and I understand their stall/spin
accident
rate is about the same as the US.
Back in the early '80s, spin training was not required and was only
marginally available. When I demanded it, after getting a little too close
for comfort on a final turn in the PA-38 Tomohawk, I had to interview more
than one additional instructor before I found one who was comfortable doing
spins.
IMHO the important point was that, once I was comfortable about the spin
entry, it was almost ridiculously easy to fly away from an incipient spin in
the C-150M and C-152. After getting over the initial discomfort, I found
that recovery during the first half turn used very little altitude and
recovering on point after 2 or 3 turns became easy. Both Cessna models
recovered very sharply on command and could have easily been flown away from
a spin entry at below 300 feet.
At that time, I was unable to find an instructor who was comfortable in the
PA-38. It remains my opinion that they simply lacked training and
experience with the aircraft; and therefore believed the scare stories which
circulated. It certainly was no less controllable, and had no less rudder
authority during a stall. Remember that there still a lot of pilots who
believe that turning a twin toward an inoperative engine is less safe than
"Russian Roulette" with 2 cartridges in the ol' wheel-gun.
Peter
Old October 16th 06, 03:24 AM posted to rec.aviation.piloting
vlado
What airplanes does this (Beggs-Mueller) not work for?
Thx,
VL
Old October 16th 06, 03:42 AM posted to rec.aviation.piloting
Jim Macklin
Not sure, but here are some guesses.
F4, A4, F104, MU2, anything with heavy span loads and
anything with small elevator and rudder.
"vlado" wrote in message
does for Pitts'),
of the stick for a
| Thx,
| VL
Old October 16th 06, 03:58 AM posted to rec.aviation.piloting
GeorgeC
Just letting go works on an F86.
On Sun, 15 Oct 2006 21:42:21 -0500, "Jim Macklin"
does for Pitts'),
of the stick for a
| Thx,
| VL
GeorgeC
Old October 16th 06, 04:11 AM posted to rec.aviation.piloting
john smith
In article . com,
Cessna 150.
Note that the Christen Eagle and Pitts were the only acro aircraft
tested extensively. Limited testing was done with the C-150.
Gene Beggs did not have the time nor the money to carry out extensive
testing on popular GA trainers and cruisers.
This research was conducted in the early 1980's.
Old October 16th 06, 04:12 AM posted to rec.aviation.piloting
vlado
john smith wrote:
In article . com,
Cessna 150.
If anyone needs to know, Beggs-Mueller does work for the T-6, T-28 and
P-51 aircraft.
VL
Old October 16th 06, 05:38 AM posted to rec.aviation.piloting
Dave Doe
In article , lefty133
@bellsouth.net says...
news
that the
about
Since
turn,
instead.
recover and
rare.
accident
spins.
I think the problem probably lies with an instructor that doesn't mind
the physical sense of spinning in a Traumahawk
(that's the trouble I had). BTW, I got an instructor to put the a/c in
a spin and recover under the hood - on one session. My recoverys were a
bit steep (I *tried* to allow for the instrument lag, honest!) But I'm
really glad I did that exercise.
Duncan
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
UK change in spin training. W.J. \(Bill\) Dean \(U.K.\). Soaring 2 June 8th 04 07:46 AM
Spin Training Captain Wubba Piloting 25 April 12th 04 02:11 PM
Spin Training JJ Sinclair Soaring 6 February 16th 04 04:49 PM
