Spin training
Old October 16th 06, 05:38 AM posted to rec.aviation.piloting
Dave Doe
Default Spin training
In article , lefty133
@bellsouth.net says...
news
On Sun, 15 Oct 2006 16:23:36 -0400, Stubby
I just got back from my spin training for my CFI....
Yup. Should be a requirement before PPL.
I believe it was required long ago, perhaps 30 years. I had a bit of
spin work in the glider. It might be required. It was fun!
Yeah, was eliminated in the late '60s, I think. Basic reason, IIRC, is
that the
number of casualties that occurred during training were thought to be
about
equal to the additional spin fatalities if training WEREN'T required.
Since
most stall/spin accidents occur at very low altitudes (the base-to-final
turn,
usually) the FAA decided to emphasize stall recognition/avoidance,
instead.
True "spin" accidents (those that occur at high enough altitudes to
recover and
not associated with any physical problem with the airplane) are quite
rare.
Canada still requires spin training, and I understand their stall/spin
accident
rate is about the same as the US.
Back in the early '80s, spin training was not required and was only
marginally available. When I demanded it, after getting a little too close
for comfort on a final turn in the PA-38 Tomohawk, I had to interview more
than one additional instructor before I found one who was comfortable doing
spins.
IMHO the important point was that, once I was comfortable about the spin
entry, it was almost ridiculously easy to fly away from an incipient spin in
the C-150M and C-152. After getting over the initial discomfort, I found
that recovery during the first half turn used very little altitude and
recovering on point after 2 or 3 turns became easy. Both Cessna models
recovered very sharply on command and could have easily been flown away from
a spin entry at below 300 feet.
At that time, I was unable to find an instructor who was comfortable in the
PA-38. It remains my opinion that they simply lacked training and
experience with the aircraft; and therefore believed the scare stories which
circulated. It certainly was no less controllable, and had no less rudder
authority during a stall. Remember that there still a lot of pilots who
believe that turning a twin toward an inoperative engine is less safe than
"Russian Roulette" with 2 cartridges in the ol' wheel-gun.
I think the problem probably lies with an instructor that doesn't mind
the physical sense of spinning in a Traumahawk
(that's the trouble I had). BTW, I got an instructor to put the a/c in
a spin and recover under the hood - on one session. My recoverys were a
bit steep (I *tried* to allow for the instrument lag, honest!) But I'm
really glad I did that exercise.
Duncan
Old October 16th 06, 05:43 AM posted to rec.aviation.piloting
Jim Macklin
My problem with the PA 38 was the number of control wheels
that broke. I heard of CFI carrying Vise-Grips to use in an
emergency. Look the AD up.
"Dave Doe" wrote in message
. nz...
| In article ,
lefty133
message
| news | On Sun, 15 Oct 2006 16:23:36 -0400, Stubby
CFI....
It was fun!
reason, IIRC, is
| that the
were thought to be
| about
WEREN'T required.
| Since
(the base-to-final
| turn,
| instead.
altitudes to
| recover and
airplane) are quite
| rare.
their stall/spin
| accident
| Ron Wanttaja
and was only
a little too close
to interview more
| spins.
discomfort, I found
little altitude and
Both Cessna models
comfortable in the
training and
scare stories which
had no less rudder
lot of pilots who
is less safe than
wheel-gun.
doesn't mind
put the a/c in
recoverys were a
honest!) But I'm
| Duncan
Old October 16th 06, 11:06 AM posted to rec.aviation.piloting
Dave Doe
In article z5EYg.3142$XX2.290@dukeread04, p51mustang[threeX12]
@xxxhotmail.calm says...
No thank you!
Wouldn't one just use the other wheel?
Duncan
Old October 16th 06, 04:36 PM posted to rec.aviation.piloting
Jim Macklin
There were reported cases of both breaking. Piper built all
the PA38 aircraft in a rush in order to beat Beech to the
market. Many of the airplanes were junk.
. nz...
wheels
in an
| No thank you!
| Duncan
Old October 17th 06, 02:08 AM posted to rec.aviation.piloting
Dave Doe
In article yKNYg.4751$XX2.3882@dukeread04, p51mustang[threeX12]
Interesting. I thought they built it in competition to the Cessna. I
know that a known potential weak point was in the T-tail, where the
thing is welded onto the control actuator (hope I've got that right). I
was told to always check that weld as best I could w' ma naked eye for
cracks.
Duncan
Old October 17th 06, 02:46 AM posted to rec.aviation.piloting
Jim Macklin
Look up Beech Skipper and Piper Tomahawk, visually nearly
identical. There was some industrial espionage with an
employee named Piper working for both companies.
Beech had a prototype flying in the mid 70s with out the T
tail, then added the T tail. Piper started the PA38 in the
late 70s and delivered over 1,000 airplanes before Beech did
their first one.
. nz...
all
the Cessna. I
where the
that right). I
naked eye for
| cracks.
| Duncan
Old October 17th 06, 01:58 PM posted to rec.aviation.piloting
john smith
In article HBWYg.5034$XX2.3466@dukeread04,
Tomahawk has a aT-tail, Skipper has a cruixiform tail.
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
UK change in spin training. W.J. \(Bill\) Dean \(U.K.\). Soaring 2 June 8th 04 07:46 AM
Spin Training Captain Wubba Piloting 25 April 12th 04 02:11 PM
Spin Training JJ Sinclair Soaring 6 February 16th 04 04:49 PM
