flap that is?
Wine were the same - finally found the problem. You need to remove a few nuts & bolts Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Wine were the same?
Wood er you tolk in bout? The cerk comes owt ferst then youse can pour the wine. Must be cold up thare, my lips don't work either when I'm cold. David Wine were the same - finally found the problem. You need to remove a few nuts & bolts Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Grob G102 Setup | BDS | Soaring | 11 | August 30th 05 03:42 PM |
Negative flaps for better low speed aileron control? | [email protected] | Soaring | 41 | August 25th 05 06:01 AM |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
