Mylar Adhesive "Best Practices"
Old October 16th 06, 11:16 PM posted to rec.aviation.soaring
Gary Emerson[_1_]
Default Mylar Adhesive "Best Practices"
For the benefit of the group, let's hear about what works for
re-attaching mylar.
I had an older generation sailplane that when I got it had fabric tape
for sealing the ailerons and elevator, but it was due for replacement so
the upgrade was to mylar. Removed the old tape and used acetone with
lots of elbow grease and paper towels to remove the gum residue from the
tape. We used "Tessa Tape" from W&W and applied that and prior to
removing the backing pressed it down onto the gelcoat very firmly. Then
we put the mylar onto that and pressed it down firmly again. Followed
that with the safety tape and no issues for 4 years.
With that said, I later bought a factory glider and within 1.5 years a
portion of mylar was coming up on a short stretch of aileron. I removed
the mylar, cleaned with acetone, followed the same procedure as above
and that section was again coming up about 1.5 years later.
The tessa tape is very sticky stuff. I did not scuff the mylar in
either case, but in the second case, the mylar was pulling up from the
tape, not the tape pulling up from the gelcoat.
Old October 17th 06, 06:31 AM posted to rec.aviation.soaring
Bruce Greef
re-attaching mylar.
I would be very careful about using Acetone on a glider, depending on the
construction you could do damage. Reliable sources indicate that acetone can
penetrate the structure and damage the foam core in GRP/foam sandwich structures.
Not being a composites specialist I can't comment. Just try to use something a
little less aggressive - like MEK.
Any experts out there?
Old October 17th 06, 10:54 AM posted to rec.aviation.soaring
01-- Zero One
"Bruce Greef" wrote in message
snip
Bruce, not an expert. but I have personal first hand experience that
repair specialists use acetone routinely to clean composites when
working with gelcoat and uncoated GRP/foam. If you soaked the composite
or left it on there a long time, I could see where perhaps it could
damage something underneath, but a brief exposure for cleaning would
appear to be OK.
Larry
"01" USA
Old October 17th 06, 01:56 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
the construction you could do damage. Reliable sources indicate that
acetone can penetrate the structure and damage the foam core in GRP/foam
I'd agree. Speaking as a model builder who molds his own composite
structures for wing D-boxes and fuselages, I'd like to make the
following points:
- the glass/carbon skin *should* be impervious to liquids but you
never know. The problem with making light, strong composites is
to get excess resin out of the layup after you've wetted out the
glass or carbon. If the wetting is thorough then blotting out as
much resin as possible and then curing under vacuum will leave
you with a compacted structure with no pinholes etc. However, if
the wetting wasn't right you will get starved looking patches that
may well be porous.
- Model dope thinner is mostly acetone. This dissolves white polystyrene
foam almost instantly. A standard way of making complex one-off glass
fuselage shells, fuel tanks etc. is to carve the shape from white
foam, cover it with glass cloth and epoxy and, when the epoxy is
cured, pour thinners onto the foam. Result: an empty shell all ready
for finishing.
- acetone wets composite surfaces really well and will wick through the
finest pores or cracks.
The moral is to test any unknown liquid of a scrap of foam (if you can
get one) before putting it on your glider unless you're certain that the
area you're working on is absolutely impervious to liquids *and* you're
sure the liquid can't run onto any part of the structure that might be
porous, cracked or has poorly adhering glue lines.
HTH
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 17th 06, 03:29 PM posted to rec.aviation.soaring
Bert Willing
FRP is not a tight surface *at all* (even if you don't see any pores).
Soaking a FRP part in acetone is certainly not a good idea.
However, wiping such a surface with acetone to remove grease or whatever
doesn't put a problem because the thin film of aceton left behind will
rapidly evaporate from the surface.
On gelcoat, however, I wouldn't use acetone, but rather ethyl alcohol.
"Martin Gregorie" wrote in message
can penetrate the structure and damage the foam core in GRP/foam sandwich
structures.
structures for wing D-boxes and fuselages, I'd like to make the following
may well be porous.
for finishing.
The moral is to test any unknown liquid of a scrap of foam (if you can get
one) before putting it on your glider unless you're certain that the area
you're working on is absolutely impervious to liquids *and* you're sure
the liquid can't run onto any part of the structure that might be porous,
HTH
org |
Old October 17th 06, 03:21 PM posted to rec.aviation.soaring
chris
I'm not going to call myself an expert but MEK is a much More Agressive
solvent on many substances. If I recall correctly many gelcoats are
styrene based. MEK will dissolve styrene quite readily, actually it is
was is used for model glue.
MEK also seems to disolve brain cells too, which may or may not be a
problem depending on what memories you want to keep.
Chris
Old October 17th 06, 06:28 PM posted to rec.aviation.soaring
Yikes.
I once had to do extensive re-repairs to a glider whe
- a previous repairer had spliced in new wing skins
- during the repair he liberally "cleaned" with MEK
- the MEK went through the joint, and disolved the foam.
This glider flew for a while, and when it was involved in
another accident the skins all cracked in the areas
where they were no longer supported by the foam core.
All the replaced skin areas had to be re-spliced !
For heavens sake, if you aren't expert, don't go
messing about with solvents you heard recommended
on RAS. Someone could get hurt, maybe you.
Be safe out there !
Best Regards, Dave
Old October 18th 06, 05:35 PM posted to rec.aviation.soaring
Bruce Greef
Yikes.
Be safe out there !
Best Regards, Dave
Hi Dave
That was meant to be humour...
But then I forget much of the world does not appreciate satire.
With a little effort you can remove things like adhesive residue with anything
from simple friction, to light vegetable oil, (peanut oil works well on most
adhesives believe it or not) without applying some corrosive health risk the
effects of which are unknown on your glider's structure. A gentle detergent will
clean just about any dirt or residue you may want to remove, without risk.
My point was that using aggressive chemicals on your glider is unwise, even in
small quantities.
So back to the original point. If you do want to use a solvent, check with the
manufacturer. Some elbow grease will probably do the job, and your fitness
levels the world of good, and not risk damage to the composites.
Cheers
Bruce
Old October 17th 06, 06:27 PM posted to rec.aviation.soaring
Shawn[_2_]
re-attaching mylar.
Now that we've established that the only solvent safe to use on a
composite glider is the sweat from a virgin Las Vegas showgirl,
can anyone answer Gary's question?
Thx,
Shawn
Re-curving mylar on a glider Eric Greenwell Soaring 32 October 18th 06 03:20 PM
Mylar (again) JJ Sinclair Soaring 0 December 11th 03 10:40 PM
Mylar "form 1" vs "form 2" John Soaring 1 November 27th 03 01:20 AM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 08:58 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 06:03 AM
