Why are multiple engines different?
Old October 18th 06, 02:03 AM posted to rec.aviation.piloting
Mxsmanic
Default Why are multiple engines different?
Sylvain writes:
ok, can you tell me how to make a movie (uploadable to video.google
or other similar places) from MS FS?
I don't know. I've never tried it.
  #262
Old October 18th 06, 10:30 AM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
Neil Gould writes:
You only think that because you have no experience in real airplanes.
No, I think that because it's true, despite any idiosyncrasy of human
psychology that causes people to deny it. Many skills and experiences
are not transferable to highly foreign contexts. Being able to hold a
plane in level flight does not equate to being able to taxi. Being
able to taxi or fly with two engines does not equate to being able to
taxi or fly with one engine failing. Furthermore, even speculating on
the unfamiliar scenario is fraught with risk.
By the time one is rated to fly -- anything, not just multi's -- one has
received training in all aspects of the operation of the plane, including
engine out. Taxiing with a single engine would be part of that training.
Even if one is already a multi-rated pilot, you can't just go hop into
some other multi-engine plane that you haven't been checked out in and go
flying. I don't know what the checkout in a Baron is, but I wouldn't be at
all surprised if it is 20-25 *hours* or more of instruction.
Neil
  #263
Old October 18th 06, 10:31 AM posted to rec.aviation.piloting
Neil Gould
Recently, Sylvain posted:
Neil Gould wrote:
there is absolutely no basis for that notion in the real world. BTW
- he *has* taxied the Baron with one engine,
actually it was a Duchess.
I stand corrected!
Neil
  #264
Old October 18th 06, 11:21 AM posted to rec.aviation.piloting
Jim Macklin
For an already rated and current MEL pilot, a Baron checkout
should be under 5 hours, perhaps a little. But insurance
coverage often will require 25-50 PIC time in that
make/model. So, you hire a CFI to ride along.
The 25-50 that are required often end up being 95% cruise
with not no engine out practice, no systems drills, very
little in the way of hand flown instrument, very little
valuable training.
Five hours of good instruction with some refresher every 6
months makes more sense.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Neil Gould" wrote in message
. com...
| Neil Gould writes:
real airplanes.
and experiences
able to hold a
taxi. Being
being able to
speculating on
multi's -- one has
plane, including
that training.
go hop into
I wouldn't be at
instruction.
| Neil
  #265
Old October 18th 06, 06:07 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
So why doesn't anyone seem to have done it?
  #266
Old October 18th 06, 06:08 PM posted to rec.aviation.piloting
Mxsmanic
"Jim Macklin" writes:
Do aircraft have to be insured? What coverage is usually taken?
  #267
Old October 19th 06, 06:12 AM posted to rec.aviation.piloting
RK Henry
On Wed, 18 Oct 2006 19:07:51 +0200, Mxsmanic
Neil Gould writes:
In fact, they do. I often see multis taxiing in to the ramp with just
one engine running. Mostly turboprops.
Curious coincidence: I just saw the show on CNBC about American
Airlines that they're saving a lot of fuel by taxiing on just one
engine.
RK Henry
  #268
Old October 19th 06, 07:11 AM posted to rec.aviation.piloting
Jim Macklin
It has to do with the thrust vector and the landing gear
geometry. Light twins tend to bind on the asymmetric thrust
and the short coupled landing gear. Turbo props and jets
are generally longer and the engines thrust further from the
nose wheel. On jet aircraft, the engines may be on the tail
and they can taxi just fine on one engine.
The airlines do anything to save fuel, but they do not
take-off with paying passengers aboard to save fuel. They
do start and taxi on one engine, but will start all engines
when nearing the take-off runway so the temperatures has
stabilized and the engine can be verified as running. On
airplanes with 4 engines I do understand that some flights
may be allowed to depart on three engines, but I have no
researched the FAR 25 or 121 to see. Also the particular
OPS manual for an airline would have to allow it.
James H. Macklin
ATP,CFI,A&P
some support
"RK Henry" wrote in message
| wrote:
| Neil Gould writes:
multi's -- one has
of that training.
ramp with just
American
just one
| engine.
| RK Henry
  #269
Old October 19th 06, 01:01 PM posted to rec.aviation.piloting
Allen[_1_]
"Jim Macklin" wrote in message
news:OOEZg.12886$XX2.1052@dukeread04...
Thank you Jim, I was going to bring this up but didn't think it was worth
the effort for this thread : ( I used to taxi a Lear 35 all the time on
one engine, starting the second after the batteries had a chance to
re-charge. I have also taxiied a Baron on one engine but it was always on a
hardsurface without any uphill incline. The distance between the thrust
source and the steering source is the key.
Boeing 727 also has procedure for two-engine take-off but usually only
minimum crew to ferry it to a place it can be worked on.
James H. Macklin
ATP,CFI,A&P
some support
| wrote:
| Neil Gould writes:
multi's -- one has
of that training.
ramp with just
American
just one
| engine.
| RK Henry
  #270
Old October 19th 06, 06:33 PM posted to rec.aviation.piloting
Jim Macklin
I think that things as simple as tire pressures and surface
would make a difference. Slope or runway gradients, current
wind would have a big effect. a crosswind might cancel the
turning moment of a single-engine or magnify it.
I've had a number of engine failures, except for one at my
home airport. After landing I would coast off the runway
and just call for a tow. When I had both fuel pumps on the
left engine of a BE 58P fail down in Texas, I just did the
same thing, landed, coasted clear and arranged for a tow to
the ramp. If I had tried to taxi and had a problem, I could
have been blocking a taxiway and caused a real problem to
the ground controller.
For those who will ask, I was returning to Wichita from
Brownsville after dropping the aircraft owners off for the
week. At FL240 near Corpus Christi the left engine died
when I turned the boost pump off [I had been using the pumps
because of hot fuel and vapor suppression on the ground]
Then the engine would not start again because of zero fuel
pressure. Did not attempt cross-feed from the right because
of concern about possible broken fuel lines.
The most difficult decision was selecting a place to land,
it does take a while to come down from FL240 and I wanted a
place where I could get repairs and an airline flight out.
It was Mothers' Day week-end so I knew there would be no
work done for a while and my wife probably wanted me home.
Declared an emergency just because I wanted the priority
handling and no traffic I had to follow. The shop in San
Antoine repaired the pumps and I picked it up the next week.
Later, back at home we ended up replacing all the pumps with
new pumps. There was still too much fuel pressure
variation. The airplane was an early 58P and it had many
hours in service formerly in air taxi service in Europe.
"Allen" wrote in message
om...
| "Jim Macklin" wrote
in message
thrust
jets
tail
think it was worth
all the time on
chance to
it was always on a
between the thrust
They
engines
has
On
flights
particular
usually only
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
| | wrote:
| | Neil Gould writes:
just
| multi's -- one has
of
part
| of that training.
| ramp with just
| American
on
| just one
| | engine.
| | RK Henry
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines Otis Willie Military Aviation 0 October 29th 03 03:31 AM
