I guess we just need to secure the shoulder straps properly ? ...
"Nyal Williams" wrote in message ... This is somewhat analagous to reported accidents by Cessna pilots on takeoff; if the adjustable seats are not properly locked in their rails the seat can slide backward, making it impossible to push the yoke forward. Perhaps we need a two-point attachment for each of the shoulder straps -- the one above the shoulders that already is in place and which keeps the body from being thrown forward, plus a second one from be bottom of the seat pan, and which would prevent the body from moving upward and aft. This second strap could also protect against cranial collision with the canopy. Anyone for seven-point harness? At 09:30 18 October 2006, Bert Willing wrote: Doug, the reading of an ASI is very rarely connected to winch launch accidents, and certainly not in the initial climb. Sliding back in the seat (or movement of a seatpan) during initial rotation has already claimed a number of lives. Bert 'Doug Haluza' wrote in message groups.com... Derek Copeland wrote: Wouldn't the exact effect depend on the relative areas of the pot pitot and the usually very small holes in the T.E. probe? The AAIB are normally very thorough in their investigations, so I am happy to believe them, and that this error was not the primary cause of the accident. Neither am I recommending that you should connect your instruments up in this way. No, the area of the openings would not matter, unless there was a significant leak. If your description is correct, then I would not assume that the primary cause was the straps, which as you point out could not be conclusively determined due to post impact damage. Can you check the report again and make sure you have correctly reported the results? |
Crouch Strap story | Ed Byars | Soaring | 43 | September 23rd 13 05:43 PM |
Air Force launches new ad campaign | Otis Willie | Military Aviation | 0 | September 14th 04 09:41 PM |
Vandenberg AFB Rocket Launches | Brian Webb | Military Aviation | 1 | September 5th 04 06:13 PM |
Vandenberg AFB Rocket Launches | Brian Webb | General Aviation | 0 | September 4th 04 11:42 PM |
NOTAMs for non-US space launches? | Allen Thomson | Military Aviation | 0 | September 25th 03 04:01 PM |
