There is an Av Gas Prist also.
Al G "Jim Macklin" wrote in message news:2_NZg.12899$XX2.1716@dukeread04... A Duchess at 25,000 feet? Sounds a little like BS to me or is that just an urban legend? Gasoline with water in the fuel system needs to be properly sumped, drained, purged of that water. If you have an underground fuel farm and pump directly into the airplane, any water in the mixture will take an hour or two minimum for the water to collect and settle into the tank sumps. If the fuel is pumped from storage into a truck and taken to the airplane, the water still needs several hours to settle. If the maintenance of the fuel trucks, filters and service practice are sloppy, you'll have lots of water in your tanks. The fuel in an underground tank or a truck needs to settle and then all the water drained. Fuel filters need to be service daily. Aircraft maintenance means that fuel cap seals must be inspected and replaced. The airplane needs to sit for two hours or more after being fueled and then the fuel sumps drained of all trapped water. Then depending on the aircraft model, the plane needs to be rocked so that water trapped in fuel tank wrinkles (Cessna AD) will move to the sumps and can then be drained again. In automobiles, chemicals such as alcohol are often sold as fuel system driers, nut alcohol should not be added to aircraft fuel. The use of Prist in the proper quantity and mixing method doesn't hurt, but Prist is primarily for Jet fuel which holds more water, grows fungus and does get thick at low temperatures. A Duchess at 25,000 feet? "Peter" wrote in message ... | | "John R. Copeland" wrote: | | Cold avgas should be no problem, assuming no suspended ice crystals. | Take care to keep your fuel clean and dry. | I often fly in the low flight levels where temperatures can be even lower. | The cold-soaked fuel flows just fine, including using a transfer pump to | move wing-locker fuel out into the tip tanks. | I've never had any avgas problems at those temperatures, | but cranking the starter against very cold oil has defeated me too many times. | Heated hangars are my favorite choice. | | This is Europe, where heated hangars are a luxury available to the | chosen few ![]() | | The specific concern wasn't the stuff flowing into the tank. It is | freezing in the pipework, especially in the injection tubes (IO540-C4 | engine, in my case) which are very thin and exposed to the full 150kt | airstream. | | There have been various cases of avgas freezing in fuel pipes, and the | pilot having to descend all the way down to god knows where to restart | the engine(s). And it's happened to twins too; one pilot I met | recently had to descend (a Duchess) with a dual engine failure from | 25,000ft to 2,000ft over the sea, 100nm away from any coast, before he | could restart. The initial temp was -25C. | |
Starting new C172s | navghtivs | Piloting | 76 | September 10th 05 09:33 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
