On Tue, 18 Jan 2005 14:55:41 +0000 (UTC),
(Paul Tomblin) wrote: In a previous article, said: On Mon, 17 Jan 2005 23:45:57 -0700, Newps wrote: wrote: Once a clearance for an approach is issued, the pilot is bound by the appropriate segments of the approach (Part 97) and the applicable parts of 91.175. Any "short cut" with either a contact, visual, or cancellation is a ^^^^^^^^^^^^ legal no-no. Baloney. Once I'm in a position to fly visually to the airport/runway I can do just that. that's not what this says, I don't think: (a) Instrument approaches to civil airports. Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter. I don't see anything there that prohibits you from cancelling IFR when you have sufficient visibility and cloud clearance to operate under VFR. you can. But you can't land at an airport that's reporting IFR conditions. |
![]() "Paul Tomblin" wrote in message ... I don't see anything there that prohibits you from cancelling IFR when you have sufficient visibility and cloud clearance to operate under VFR. Nope. But if you can operate under VFR an instrument letdown wouldn't be necessary. |
![]() "Steven P. McNicoll" wrote in message nk.net... "Paul Tomblin" wrote in message ... I don't see anything there that prohibits you from cancelling IFR when you have sufficient visibility and cloud clearance to operate under VFR. Nope. But if you can operate under VFR an instrument letdown wouldn't be necessary. Paul stated "canceling when you have sufficient visibility..." which indicates a change in status/condition/visibility (at the point visibility becomes adequate). Your reply infers that there was adequate visibility prior to that. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
![]() "Matt Barrow" wrote in message ... Paul stated "canceling when you have sufficient visibility..." which indicates a change in status/condition/visibility (at the point visibility becomes adequate). Paul wasn't following the thread very closely. The message he responded to stated "when an instrument letdown to a civil airport is necessary". As I said, if you can operate under VFR an instrument letdown wouldn't be necessary. Your reply infers that there was adequate visibility prior to that. No, you're inferring. |
In a previous article, "Steven P. McNicoll" said:
"Matt Barrow" wrote in message ... Paul stated "canceling when you have sufficient visibility..." which indicates a change in status/condition/visibility (at the point visibility becomes adequate). Paul wasn't following the thread very closely. The message he responded to stated "when an instrument letdown to a civil airport is necessary". As I said, if you can operate under VFR an instrument letdown wouldn't be necessary. That was precisely the point I was trying to make, since somebody else brought up the "when an instrument letdown ... is necessary" as a reason why one *couldn't* cancel IFR once you were on an approach. -- Paul Tomblin http://xcski.com/blogs/pt/ If netcat is compiled with -DGAPING_SECURITY_HOLE, the -e argument specifies a program to exec after making or receiving a successful connection. -- netcat README file |
![]() "Paul Tomblin" wrote in message ... That was precisely the point I was trying to make, since somebody else brought up the "when an instrument letdown ... is necessary" as a reason why one *couldn't* cancel IFR once you were on an approach. Well, you failed. |
![]() "Steven P. McNicoll" wrote in message nk.net... "Paul Tomblin" wrote in message ... That was precisely the point I was trying to make, since somebody else brought up the "when an instrument letdown ... is necessary" as a reason why one *couldn't* cancel IFR once you were on an approach. Well, you failed. The only failure was your change in context. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Steven P. McNicoll" said: "Matt Barrow" wrote in message ... Paul stated "canceling when you have sufficient visibility..." which indicates a change in status/condition/visibility (at the point visibility becomes adequate). Paul wasn't following the thread very closely. The message he responded to stated "when an instrument letdown to a civil airport is necessary". As I said, if you can operate under VFR an instrument letdown wouldn't be necessary. That was precisely the point I was trying to make, since somebody else brought up the "when an instrument letdown ... is necessary" as a reason why one *couldn't* cancel IFR once you were on an approach. Seems obvious to me. Why is McNicoll changing the context 180 degrees? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
![]() "Matt Barrow" wrote in message news ![]() Seems obvious to me. Why is McNicoll changing the context 180 degrees? Seems you and Paul made the same mistake. |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
GPS approach question | Matt Whiting | Instrument Flight Rules | 8 | November 1st 04 10:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
