Dual glide slope, $95...priceless!
Old October 21st 06, 05:33 AM posted to rec.aviation.owning
Jack Allison[_1_]
Default Dual glide slope, $95...priceless!
Robert M. Gary wrote:
The older VOR heads (the ones fed by the KX-170B style, not the KX-155
style) can be relied upon to be 6 degrees off every couple of months.
The one that was off is a newer Garmin, installed along with the GNS430
by the previous owner. While I haven't checked the logs on this, I'd
bet it hasn't been tuned since then. During the first 1.5 years of
ownership, both VORs were never more than +/- one degree.
Although technically an avionics shop needs to do the adjustment most
owners puchase the spline screwdriver and do the adjustment themselves.
You simply remove the OBS knob (via set screw) and there adjustment
screw is behind it. Usually I do it as MHR or SAC where you have a VOT.
Hmmm, interesting...not something that gets logged I'd bet :-)
Jack Allison
PP-ASEL-Instrument Airplane
"To become a Jedi knight, you must master a single force. To become
a private pilot you must strive to master four of them"
- Rod Machado
(Remove the obvious from address to reply via e-mail)
Old October 21st 06, 05:42 PM posted to rec.aviation.owning
RST Engineering
Jack, you are going to be in the position of the guy with two wris****ches.
He's never sure exactly what time it is.
"Jack Allison" wrote in message
Yes, and that setscrew is a SPLINE, and a little tiny bugger at that. It
takes the smallest spline in my toolbox to get it off. The screwdriver
needs to be a small long shaft as well...I've got an old footlong
eighth-inch fiberglass "TV Tuner adjuster" that works for me.
Log? You keep a LOG?????
Old October 21st 06, 11:22 PM posted to rec.aviation.owning
Jack Allison[_1_]
LOL..."Ok we're above glide slope, no below glide slope, left of course,
on course...aw heck, average everything out between the two glide slopes
and localizers"
Sounds like I need to get me one of those...um...for...er...when I need
to tune my TV :-)
Well, yeah, gotta have some place to put those expensive stickers the
shops type up for us...on those occasions where we opt to have them work
on the plane that is :-)
Jack Allison
- Rod Machado
Old October 22nd 06, 03:45 AM posted to rec.aviation.owning
Robert M. Gary
Interesting, those are normally highly accurate. I also have two
glideslopes. I always tell myself I should set both but almost always
forget. Even when I do set it, I tend to forget to look at the #2.
However, I do take careful note of the FAF altitude as a GS
verification.
-Robert
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Glide Slope Antenna Ground Plane JKimmel Home Built 6 August 1st 06 01:28 AM
En route glide slope? Andrew Gideon Piloting 17 November 21st 04 05:49 PM
Effect of airbrake blade height on glide slope Mike Soaring 1 January 30th 04 08:24 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
