Common instruments on small aircraft
Old October 22nd 06, 04:53 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Default Common instruments on small aircraft
"Ron Wanttaja" wrote
Take a look, then, at a photo of the panel of *my* airplane:
http://www.wanttaja.com/hhrad2.JPG
Be afraid. Be very afraid. :-)
I can't help but notice that your "fun" meter is pegged, even while it is
sitting on the ground. You really need to get that thing worked on. It should
not move off the bottom peg at least until you start the engine, and not peg
until you get airborn.
You never know when you are going to get a ramp inspection, and have an
inspector ground you for having a necessary instrument being inoperative.
Please attend to this, at your earliest convenience. I will be alerting your
local FAA inspectors to the problem, for your safety, of course.
Sincerely;
Jim in NC
Old October 22nd 06, 09:07 AM posted to rec.aviation.piloting,rec.aviation.student
It's a *recording* fun meter, like a G-Meter. :-)
Old October 22nd 06, 05:42 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
should
OK, it's a cumulative thing, eh? I guess you are in original factory new
specifications, then.
I will call the FAA, and tell them not to visit you.
I have my eye on you, though! ;-)
Jim in NC
Old October 22nd 06, 05:55 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
"Morgans" wrote in
is sitting on the ground. You really need to get that thing worked on.
It should not move off the bottom peg at least until you start the
engine, and not peg until you get airborn.
I dunno. That plane looks fun even on the ground!
Old October 22nd 06, 08:58 AM posted to rec.aviation.piloting,rec.aviation.student
Alt Beer
"Ron Wanttaja" wrote in message
On Sat, 21 Oct 2006 23:02:49 +0200, Mxsmanic wrote:
Judah writes:
The first plane I trained in was as basic as they get - one radio, one
NAV.
It was adequate as a trainer, and even for renting (although I bought
a
handheld GPS after I started renting more frequently). But they sold
that
flight school and I don't think you can rent those planes anymore.
I think I'd be worried in a plane like that.
Looks like an IC-T8 ham rig on the panel.
Old October 22nd 06, 09:26 AM posted to rec.aviation.piloting,rec.aviation.student
Close. IC-A5 aircraft transceiver. Built in, powered by the aircraft electrical
system, hooked to the standard PTT switch. Replaced a defunct Narco, weighs
less than a pound. Hooked to an antenna made from Radio Shack and plumbing
parts.
http://www.bowersflybaby.com/stories/antenna.htm
Old October 22nd 06, 06:06 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
electrical
parts.
I thought your electrical system consisted of a gel cell battery for the radio
and lights, charged on the ground by a 110V
battery charger. No?
I might have you confused with someone else. It does not happen very often. Me
getting confused, that is. At least I don't think it does. :-)
Jim in NC
Old October 22nd 06, 06:24 PM posted to rec.aviation.piloting,rec.aviation.student
electrical
parts.
Add this to one of the times, then. :-) I've got a "normal" electrical system
in Moonraker, though given my preference, I would have preferred just a battery.
Too damn much weight in the generator, battery, and starter, though I did switch
to an Odyssey dry cell a couple of years back.
Old October 22nd 06, 09:06 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Wanttaja writes:
Where are the cabin pressure controls and the FMCs?
Old October 22nd 06, 09:28 AM posted to rec.aviation.piloting,rec.aviation.student
They fall away with the SRBs.
http://www.bowersflybaby.com/stories/leoraker.JPG
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
