![]() "Roger (K8RI)" wrote How about the Barracuda? Does the Barracuda get its strength from its skin, or from a wooden framework with plywood covering it? I don't know. -- Jim in NC |
On Sat, 21 Oct 2006 13:58:52 -0400, "Morgans"
wrote: "Roger (K8RI)" wrote How about the Barracuda? Does the Barracuda get its strength from its skin, or from a wooden framework with plywood covering it? I don't know. Again as I recall the Barracuda has a Warren Truss Fuselage, that is it has both verticle and diagonal members. the strength is shared. On the other hand DeHavilland aircraft frame had only verticle members therefore the skin prevented the structure from skewing. |
On Sat, 21 Oct 2006 20:56:12 GMT, Ed Sullivan
wrote: On Sat, 21 Oct 2006 13:58:52 -0400, "Morgans" wrote: "Roger (K8RI)" wrote How about the Barracuda? Does the Barracuda get its strength from its skin, or from a wooden framework with plywood covering it? I don't know. I'm not sure how much strength the skin addes in the Cuda so I passed this question on the the Barracuda users group. If my memory holds out I'll bring their answer(s) back. Again as I recall the Barracuda has a Warren Truss Fuselage, that is it has both verticle and diagonal members. the strength is shared. On the other hand DeHavilland aircraft frame had only verticle members therefore the skin prevented the structure from skewing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
It is called "complimentary structure". Most GA aircraft have a
structure consisting of a skin (alum or plywood) that carries most of the load. However, the stringers and longerons have an important function, that is, they provide out of plane stiffness to the skin, thereby preventing it from buckling under load. Each element of the structure has an axis about which it is weak, and it needs the other elements to provide strength in that direction. They need each other very much. Bud Morgans wrote: "Roger (K8RI)" wrote How about the Barracuda? Does the Barracuda get its strength from its skin, or from a wooden framework with plywood covering it? I don't know. -- Jim in NC |
Yes, you are correct. Thanks.
Bud Orval Fairbairn wrote: In article .com, wrote: wrote: Semi-Monocoque is the term, not "complimentary." Whatever. My professor in graduate school (a Stanford Ph.D.) called it complimentary, since the stringers and longerons compliment the skin in that, as I said, they provide strength in a direction that the skin does not have, which is out of plane stiffness. Since a true Mono (meaning a single) coque (shell) structure has only a shell for structure (an egg is a perfect example), any deviation from this is often called semi-monocoque, even when the skin carries no load, which is an incorrect way of describing such a structure. You mean "complementary," meaning "completes the function," not "complimentary," as in "offerimg compliments." |
I refer the original poster to Low Power Laminar A/C Design by P.
Strojnik... A series of three books... Fascinating reading... The EAA should have them at the book store... But, to answer the question, the biggest impediment to the home builder for making a monocoque fuselage in wood is the need for a plug to cold mold or laminate the wood onto... If the fuse is symmetrical, a half plug will work and join the two halves later... The favored material is cement for making the plug, mostly for cost reasons I suspect - it certainly would hamper portability... The Mosquito was done this way, as was (I believe) much of the Spruce Goose... Much of the Cirrus airplanes are plug molded as semi-monocoque structures, but I don't think they use cement plugs ![]() denny |
compound curves in plywood | BA-100 | Home Built | 58 | April 13th 05 05:29 AM |
cvjetkovic ca-65 skyfly- plywood spar? | patrick mitchel | Home Built | 3 | October 16th 04 05:26 PM |
Air Conditioning System for Homebuilts? | JPAviation | Home Built | 18 | February 6th 04 03:24 AM |
Homebuilts by State | Ron Wanttaja | Home Built | 14 | October 15th 03 08:30 PM |
Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 08:02 PM |
