Mitty wrote
You don't have a POH? You know, he might not even have an airplane. He just asked a question and expected an answer, not a wise crack. No POH required, answer is not aircraft specific, see: http://www.kellyaerospace.com/articl...bocharging.pdf Bob Moore |
Possibly Cessna and Piper have not seen your chart. I have several POHs he
An Arrow PA28R-201 POH shows 75% power, full throttle, at 6,000 feet/2400 RPM and 7,500/2700 RPM. 65% power at about 9,800/2400 and 12,000/2700. (IO-360/200 Lyc.) A Cessna 182T (T-model, not T for turbo) POH has tables that are a little harder to read than the Arrow's graphs, but the highest % power they show at 8,000 feet is 74% and at 12,000 feet 64%. (IO-540/230 Lyc.) A carburated Cherokee Six/260 shows 75% power, full throttle, at 8,300 feet and 65% power at 11,200 feet. Engine RPM is not stated. (O-540/260 Lyc.) I also have a tiny and very complicated power chart from Lycoming for the O-540 but I am too lazy to figure it out. I am no fluid dynamicist (and may be about to prove it), but my dim understanding is that the Reynolds number has a major effect on fluid flow and in its calculation there is a density term. Certainly the mixture velocities at various points in each different intake system would be different. Velocity is also a term in the Reynolds number calculation. So (leaping) it does not surprise me that intake systems with different geometries would perform at least slightly differently at different altitudes. Exhaust systems, too, I'd guess. Possibly I should have been more diplomatic in how I suggested that the OP needed a POH but that still seems to me to be the case. On 10/21/2006 12:46 PM, Bob Moore wrote the following: Mitty wrote You don't have a POH? You know, he might not even have an airplane. He just asked a question and expected an answer, not a wise crack. No POH required, answer is not aircraft specific, see: http://www.kellyaerospace.com/articl...bocharging.pdf Bob Moore |
Backup Flight Data Recorder? | Fox Two | Soaring | 14 | August 27th 06 09:42 AM |
The Deaf vs. The Colorblind | Bret Ludwig | Piloting | 17 | August 21st 06 02:08 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
Change in TAS with constant Power and increasing altitude. | Big John | Home Built | 6 | July 13th 03 03:29 PM |
