Dick,
Since you indicated you did not wish to use a venturi, one alternative that had been used in the 20-30s for sufficient vacuum/flowrate to reliably operate a Turn and Bank is to tap off your motor's intake spider downstream of the carb (on a Continental, you could use one of the pre-threaded primer fitting holes). What you do is start with a fitting a small hole (~#40 or so) and, by a series of iterative enlargements, adjust until the level of desired vacuum was reached at cruise power. This is similar to the standby vacuum systems now sold for modern aircraft but, as the old vacuum T&Bs needed less vacuum levels/airflow, one would normally have sufficient vacuum throughout most flight regimes. Just a thought. Mike Bednarek "Dick" wrote in message m... Staring at my empty instrument panel while considering which instruments and their placement, I got wondering how old time Mail pilots flew if caught in IFR conditions. On my project plane, I'm considering just a airspeed/altitude/ ball & tube slip (no needle) indicator/compass setup in order to avoid the venturi or vacuum pump setup. Since I consider "electric" too expensive and wondered whether a dome style compass might be the key?? Any thoughts would be appreciated. Thanks, Dick -Lakeland, Florida |
