Mike Spera wrote:
Its bbbbaaaaaaacccccckkkkkkk. I thought we had the 396 reception problems solved with the unit swap and upgraded firmware. On climb out the thing lost its lock again and continued to do so until I changed course. That ain't gonna be an option on a plan in IMC (uh, center, I need to change heading 30 degrees or so to get my VFR GPS back on line...). I tried switching freqs. on the nav and com radios to avoid harmonic interference. No difference. I wonder why this cropped up after 3+ months of problem free reception??? Last time this was happening, I tried running the unit on batteries, switching the GPS antenna around, and a host of other things. Nothing helped until I upgraded the firmware on a new unit. It has been solid since then with 6+ sats near the top. Now, garbage again. Anyone else see this problem on theirs? Thanks, Mike Hmmmm. Interesting. I was just about to send my unit in. Now I wonder if I should. I did pretty much every troubleshooting procedure I could think of, including Garmin's own "hard reset" procedure, running with the master switch off in flight for about 5 minutes to positively eliminate aircraft radios as a problem, running on battery, swapping antennas, power cycling it, leaving it off for 5-10 minutes, etc. etc. etc. All to no avail. Incidentally, I have a GNS430 in the panel and compared satellite reception when the 396 went deaf. The 430 had 12 sats with the signal bars maxed on 9 of them. This is not the result of localized GPS jamming tests. It may, however, be the result of terrestrial transmissions combined with poor shielding of the 396's receiver. It's happened several times in my local flying area (New Jersey) but it's also happened over the Carolinas and Virginia. Garmin has told me I'm running the latest powered antenna (it's a 2x3" rectangular unit...I forget the model number). The earlier square units apparently had problems. I'm running firmware version 3.6 and have seen this problem since version 3.0, which was (interestingly enough) installed when it was about 3 months old. I have a copy of the 2.4, 2.6, and 2.8 firmware -- all of which were trouble-free -- and as a last ditch effort I'm planning to downgrade to one of those (likely 2.8). Garmin has said that should work. If it doesn't it won't have far to fall into the shipping box. Good luck. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
Garmin user waypoints | Jim Macklin | Piloting | 1 | January 5th 06 06:12 PM |
Garmin user waypoints | Jim Macklin | Instrument Flight Rules | 1 | January 5th 06 06:12 PM |
Garmin 430 Reception | Jon Kraus | Piloting | 16 | November 7th 04 03:17 AM |
Garmin 430 VOR reception | Maik | Piloting | 11 | September 30th 04 03:49 PM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
