Tony Verhulst wrote:
Travis Beach wrote: Just got my first sailplane...what kind of tools do you carry everytime you go to the airfield to fly? Whats in your toolbox? Only 2 items - a can of WD-40 and a roll of duct tape. If something moves and shouldn't, use the duct tape. If some thing doesn't move and should, use the WD-40. WD-40 does dry out and get sticky as time passes. This can affect delicate mechanical bits. In the model plane game we've found that spraying a clockwork timer with WD-40 to wash out grit, e.g. after the model d/ts on a ploughed field, is fine for the rest of the day. However, the timer is likely to be unreliable after enough time has passed for the WD-40's solvent to evaporate. I'm not sure how relevant this is to general glider maintenance, but it would pay to be careful what you use WD-40 on and/or carefully clean it off once the part is unfrozen. Then lube carefully with the correct lubricant. Never let the stuff near your instrument panel. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Mechanics Toolbox | Stache | Piloting | 0 | October 13th 06 04:16 AM |
FS: Snap-on aviation style toolbox | mike | Home Built | 0 | October 18th 03 07:27 PM |
FS: Aviation toolbox Snap-on KR-562 | mike | Aviation Marketplace | 0 | October 17th 03 02:45 AM |
