![]() "Larry Dighera" wrote in message .. . | On Wed, 25 Oct 2006 06:17:38 -0500, "Jim Macklin" | wrote in | : | | | BFD, All those radios are called Aids to navigation for a | reason, they are conveniences. | | Were you aware of the design flaw in GPS as implemented? I just | thought it might be a good idea to provide the information to those | weren't. | | Of course, this issue makes no mention of solar mass ejections, that | can potentially knock out any satellite. | | It appears that we are (finally?) seeing some technological innovation | tickling down to the GA fleet, but I'm becoming uneasy with the | apparent lack of robustness engineered in these early systems. | | | CAL found Paris with just a compass and a chart. | | Yes. It was an Earth Inductor Compass*. I've never seen one of those | in any aircraft in which I've flown, let alone piloted. | | | * http://oldbeacon.com/beacon/earth_inductor_compass.htm On Wed, 25 Oct 2006 14:38:27 -0500, "Jim Macklin" wrote in : An early version if the slaved compass, just like nearly all cabin class and all G1000 systems use. Correct me if I'm wrong, but doesn't a slaved compass require electrical power to operate? "Slim's" Earth Inductor Compass didn't require any power except that generated by the coil rotating in the Earth's magnetic field. So if I'm correct, those pilots flying behind a dead glass-cockpit would only have a whiskey compass to navigate with. |
The Earth compass, was powered by a windmill, just as many
crop dusters power their spray pumps, and similarly to using a venturi to power gyros, if you're flying you have power. Using a retractable generator is even part of the modern jet airliner. Yes, when your G1000 dies, you will have very limited navigation or even communication options. Check out the difference between a Beech Baron or Bonanza G36/G58 and a Cessna NAV III on the manual section at Garmin. com "Larry Dighera" wrote in message ... | | | "Larry Dighera" wrote in message | .. . | | On Wed, 25 Oct 2006 06:17:38 -0500, "Jim Macklin" | | wrote in | | : | | | | | | BFD, All those radios are called Aids to navigation for | a | | reason, they are conveniences. | | | | Were you aware of the design flaw in GPS as implemented? | I just | | thought it might be a good idea to provide the information | to those | | weren't. | | | | Of course, this issue makes no mention of solar mass | ejections, that | | can potentially knock out any satellite. | | | | It appears that we are (finally?) seeing some | technological innovation | | tickling down to the GA fleet, but I'm becoming uneasy | with the | | apparent lack of robustness engineered in these early | systems. | | | | | | CAL found Paris with just a compass and a chart. | | | | Yes. It was an Earth Inductor Compass*. I've never seen | one of those | | in any aircraft in which I've flown, let alone piloted. | | | | | | * http://oldbeacon.com/beacon/earth_inductor_compass.htm | | On Wed, 25 Oct 2006 14:38:27 -0500, "Jim Macklin" | wrote in | : | | An early version if the slaved compass, just like nearly all | cabin class and all G1000 systems use. | | Correct me if I'm wrong, but doesn't a slaved compass require | electrical power to operate? "Slim's" Earth Inductor Compass didn't | require any power except that generated by the coil rotating in the | Earth's magnetic field. So if I'm correct, those pilots flying behind | a dead glass-cockpit would only have a whiskey compass to navigate | with. |
On Wed, 25 Oct 2006 17:54:17 -0500, "Jim Macklin"
wrote in : The Earth compass, was powered by a windmill, just as many crop dusters power their spray pumps, and similarly to using a venturi to power gyros, if you're flying you have power. Using a retractable generator is even part of the modern jet airliner. A propeller turned an armature, but there were no field coils; the Earth's magnetic field played that role; thus no battery, nor generator, nor venturi, nor vacuum pump nor any other power source was required to operate it, unlike a slaved compass.. Yes, when your G1000 dies, you will have very limited navigation or even communication options. If you're in IMC at the time of such a failure, you're only landing option will be a GCA approach, unless you have portable Nav equipment. Check out the difference between a Beech Baron or Bonanza G36/G58 and a Cessna NAV III on the manual section at Garmin. com What will I find? |
One point, any proper weather briefing will determine where
and how far VFR conditions exist. Did that 30 years ago. If you don't have any more than a compass you can find North Dakota or Texas from Chicago or Atlanta. Today, even a $100 GPS will steer you pretty well ands aircraft walkie-talkies are common, not so 30 years ago. But even without GPS or radar, I could find a safe place to land. "Larry Dighera" wrote in message ... | On Wed, 25 Oct 2006 17:54:17 -0500, "Jim Macklin" | wrote in | : | | The Earth compass, was powered by a windmill, just as many | crop dusters power their spray pumps, and similarly to using | a venturi to power gyros, if you're flying you have power. | Using a retractable generator is even part of the modern jet | airliner. | | A propeller turned an armature, but there were no field coils; the | Earth's magnetic field played that role; thus no battery, nor | generator, nor venturi, nor vacuum pump nor any other power source was | required to operate it, unlike a slaved compass.. | | Yes, when your G1000 dies, you will have very limited | navigation or even communication options. | | If you're in IMC at the time of such a failure, you're only landing | option will be a GCA approach, unless you have portable Nav equipment. | | Check out the | difference between a Beech Baron or Bonanza G36/G58 and a | Cessna NAV III on the manual section at Garmin. com | | What will I find? |
Removing Ethanol from Gas? | Jay Honeck | Piloting | 67 | August 16th 06 03:29 PM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Piloting | 7 | March 14th 05 07:36 AM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 07:36 AM |
