IFR in the Eastern Mountains
Old October 26th 06, 03:47 PM posted to rec.aviation.ifr
Default IFR in the Eastern Mountains
: I am thinking of a flight into Ingalls airport in Hot Springs, VA this Fall.
: It's elevation is 3,792' and has a 5000+ foot runway. It is surrounded by
: several washboard-like mountains. Look at the picture on airnav:
: http://tinyurl.com/yn6hrm Also click on this link to see a really nice
: hotel near the field: http://tinyurl.com/ygxfez
HSP is only about 50 miles from me... I've been there a number of times. If
you're looking to look at the leaves, you're already kinda late. The higher
elevations around here are pretty much already changed and dropped. The runway is
great, long, and wide, but there *are* some pretty hazardous air currents right off
the end of the runway. (Basically right off the end of the runway is a cliff that
drops probably at least 1000'... supposedly a few airplane wrecks can be found down
there).
Rules of the "mountains" here seem to be similar to out west, only less-so.
Density altitude can make a mess of you. Turbulence, lift, and sink can be a problem
in windy conditions (especially this time of year). Don't push the aircraft
performance envelope, and don't do anything stupid while clearing ridges and you'll be
fine. ... a good example of stupid would be coming in slow at HSP where you're very
likely to get sink off the end of the runway. Plenty of runway, so keep it fast.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old October 26th 06, 04:17 PM posted to rec.aviation.ifr
Kobra[_1_]
If
higher
runway is
right off
cliff that
found down
there).
less-so.
be a problem
aircraft
and you'll be
you're very
it fast.
Great advice...thanks so much.
Kobra
New Plane and Mountains randall g Piloting 9 October 13th 06 01:48 AM
Ely (and Eastern Nevada) airspace grab Kemp Soaring 0 January 31st 06 05:55 AM
Glider Pilots Ground School - Eastern PA Bob Lacovara Soaring 0 December 24th 05 02:18 PM
CVS AnyWhereMap in Eastern Oklahoma sidk Piloting 0 October 22nd 04 12:40 AM
Judge halts work on Navy landing field in eastern N.C. Otis Willie Naval Aviation 1 April 21st 04 12:04 PM
