![]() CKonikoff wrote: Sorry, but I missed the original posting. I believe that at GPT there is no V522, only V552. Maybe they charted something wrong and the NOTAM was to change the error, V522, to the correct airway, V552. DC 5/0505 GPT FI/T GULFPORT-BILOXI INTL, GULFPORT, MS. ILS OR LOC RWY 14, AMDT 14... CHANGE PLANVIEW NOTE: PROCEDURE NA FOR ARRIVALS AT CAESA VIA V552 WESTBOUND VICE V522 WESTBOUND. IF and only IF I was wanting to do a full procedure approach coming from any other direction then westbound, would a procedure turn be authorized based on the above FDC? If not, what is this FDC about? They made a mistake on the airway number. What the NOTAM clarifies is that you cannot do the procedure at all arriving on V552 from the east, because it exceeds the 120-degree course change limitation of TERPs Paragraph 220. CAESA is on V552, so it is not possible to do the procedure turn arriving on that route. Arriving on V-552 from the west results in less than a 120-degree course change at CAESA, and because "NoPT" is authorized after CAESA, it's straight-in from that direction on V-552. It's only been in the past three years or so that they have started adding these course change limitation notes to IAPs, although the requirement has always existed in TERPS (subparagraph "b" below): 220. FEEDER ROUTES. When the IAF is part of the enroute structure there may be no need to designate additional routes for aircraft to proceed to the IAF. In some cases, however, it is necessary to designate feeder routes from the enroute structure to the IAF. Only those feeder routes which provide an operational advantage shall be established and published. These should coincide with the local air traffic flow. The length of the feeder route shall not exceed the operational service volume of the facilities which provide navigational guidance unless additional frequency protection is provided. Enroute airway obstacle clearance criteria shall apply to feeder routes. The minimum altitude established on feeder routes shall not be less than the altitude established at the IAF. a. Construction of a feeder route connecting to a course reversal segment. The area considered for obstacle evaluation is oriented along the feeder route at a width appropriate to the type of route (VOR or NDB). The area terminates at the course reversal fix, and is defined by a line perpendicular to the feeder course through the course reversal fix. b. The angle of intersection between the feeder route course and the next straight segment (feeder/initial) course shall not exceed 120°. c. Descent Gradient. The OPTIMUM descent gradient in the feeder route is 250 feet per mile. Where a higher descent gradient is necessary, the MAXIMUM permissible gradient is 500 feet per mile. The OPTIMUM descent gradient for high altitude penetrations is 800 feet per mile. Where a higher descent gradient is necessary, the MAXIMUM permissible is 1,000 feet per mile. |
![]() Jepp chart is posted at alt.binaries.pictures. aviation |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
