Another SR22
Old October 27th 06, 02:16 AM posted to rec.aviation.piloting
Larry Dighera
Default Another SR22
On Thu, 26 Oct 2006 16:56:50 -0500, "Gig 601XL Builder"
wrDOTgiaconaATcox.net wrote in :
Does the POH mention when it may be appropriate to deploy the 'chute?
I thought it was for use in spin recovery.
From the manual
[excerpt deleted]
Thank you.
What does the POH say about CAPS deployment for spin recovery?
Old October 27th 06, 02:36 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Larry Dighera" wrote in message
From the manual
[excerpt deleted]
Thank you.
You know Larry the URL for the manual was in the upstream post but since I
downloaded the whole book.
Spins
The SR22 is not approved for spins, and has not been tested or
certified for spin recovery characteristics. The only approved and
demonstrated method of spin recovery is activation of the Cirrus
Airframe Parachute System (See CAPS Deployment, this section).
Because of this, if the aircraft "departs controlled flight," the CAPS
must be deployed.
While the stall characteristics of the SR22 make accidental entry into a
spin extremely unlikely, it is possible. Spin entry can be avoided by
using good airmanship: coordinated use of controls in turns, proper
airspeed control following the recommendations of this Handbook, and
never abusing the flight controls with accelerated inputs when close to
the stall (see Stalls, Section 4).
If, at the stall, the controls are misapplied and abused accelerated
inputs are made to the elevator, rudder and/or ailerons, an abrupt wing
drop may be felt and a spiral or spin may be entered. In some cases it
may be difficult to determine if the aircraft has entered a spiral or the
beginning of a spin.
.. WARNING .
In all cases, if the aircraft enters an unusual attitude from
which recovery is not expected before ground impact,
immediate deployment of the CAPS is required.
The minimum demonstrated altitude loss for a CAPS
deployment from a one-turn spin is 920 feet. Activation at
higher altitudes provides enhanced safety margins for
parachute recoveries. Do not waste time and altitude trying to
recover from a spiral/spin before activating CAPS.
Inadvertent Spin Entry
1.
CAPS.............................................. ...................................
Activate
Old October 27th 06, 02:55 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 08:36:26 -0500, "Gig 601XL Builder"
From the manual
[excerpt deleted]
Thank you.
Thank you for the information.
Spins
must be deployed.
. WARNING .
That seems to confirm, that the CAPS was required to the meet spin
recovery requirements for FAA certification of the SR22.
But if the aircraft is below 1,000', the CAPS system is probably not
an option.
Thank you again for providing the SR22 POH quotes.
Old October 27th 06, 03:06 PM posted to rec.aviation.piloting
Thomas Borchert
Larry,
an option.
IF you are in a fully developed spin (1 full turn, as certification
requires and the handbook says), traditional spin recovery isn't an
option either at 1000 feet. There is a limit to altitude loss during
recovery to meet certification. The chute obviously qualifies.
Thomas Borchert (EDDH)
Old October 27th 06, 03:46 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 16:06:45 +0200, Thomas Borchert
wrote in
Larry,
an option.
Obviously.
However, if you have, for example, an engine failure at 400' on
departure, the CAPS is not an option.
My point is, that CAPS is not an option at the times it's needed most:
below 920'. So to characterize the SR22 CAPS as a safety enhancement
(for other than spin recovery, and possibly a MAC, structural failure,
loss of control, and landing in inhospitable terrain, *if* they occur
above 920') is inappropriate. (And CAPS use for recovery in the event
of pilot incapacitation is a judgment call specific to the incident.)
Personally, I would characterize the SR22 CAPS solely as a
certification requirement for spin recovery, with limited utility in a
few other emergency situations, and certainly not as a "panic-button"
capable of rescuing the flight from all perils.
Old October 27th 06, 04:18 PM posted to rec.aviation.piloting
Thomas Borchert
Larry,
How do you arrive at that conclusion?
below 920'.
That's not what your own quote says. It says it is not an option if you
arrive at less than 920 feet after one full turn in a spin.
Well, the people saved by it in different circumstances would probably
beg to differ.
Old October 27th 06, 05:57 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 17:18:30 +0200, Thomas Borchert
wrote in
Larry,
The way I read the quote from the SR22 POH, it requires 920' to fully
deploy the CAPS. Do you have information to the contrary?
below 920'.
So you feel that less altitude would be required for full CAPS
deployment if the aircraft hadn't archived "one full turn in a spin?"
You'll have to cite some objective information that supports that
notion before I'll change my opinion from what is written in the SR22
POH.
beg to differ.
Are you able to provide any credible information about the
circumstances to which you refer?
Old October 27th 06, 07:22 PM posted to rec.aviation.piloting
Jim Logajan
The Nall Report (NR) indicates the phase of flight with the most fatal
pilot-caused accidents (~78% of all fatal accidents) is during what it
calls "maneuvering" (~23%). Since the NR categorizes descent/approach,
landing, go-around, and takeoff/climb distinct from maneuvering, the
maneuvering category would appear to encompass flight regimes presumably at
pattern and cruise altitudes. I would presume then that CAPS would be a
viable option in a large fraction of these cases.
Looking at the way the NR categorizes pilot caused fatal accidents, it
seems to me that about half the categories are such that the fatalities
could in theory have been prevented with CAPS. So CAPS might have been
potentually life-saving in about 0.78*0.5 = ~40% of all fatal GA accidents.
The non-pilot caused accidents allegedly accounted for ~22% of accidents,
but the fraction that happened at altitudes sufficient for effective CAPS
deployment is unknown. Assuming SWAG of ~50% of those 22% happened at
altitudes high enough for CAPS use, then CAPS would be potentially life-
saving in ~11%.
So in theory if all GA craft were equipped with CAPS and pilots were
trained in their effective use, they might cut the number of fatalities in
GA accidents by roughly half.
Old October 27th 06, 07:47 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 18:22:34 -0000, Jim Logajan
wrote in :
Pattern altitude for light GA aircraft is typically 800' AGL, so it's
not clear that SR22 CAPS would fully deploy from that altitude. Even
at a 1,000' pattern altitude, the aircraft would likely be below 920'
before the PIC realized the necessity for deploying the SR22 CAPS.
What sort of maneuvering above 920' AGL would cause a fatal mishap,
other than a MAC?
So you feel that the PIC in those fatal accidents would have had
sufficient altitude to assess the nature of the emergency and decide
to deploy the CAPS with 920' feet to spare?
I'm having a difficult time thinking of what the cause of such
accidents might be. CFIT doesn't fit. I agree, that a MAC might
permit a pilot to deploy a CAPS, unless it was similar to November 16,
2000 C-172 vs F-16 MAC that disintegrated the pilot and his Skyhawk.
I'd have to know more about the nature of the criteria you used in
arriving at that conclusion before I'd accept it.
saving in ~11%.
Only if one accepts your assumptions.
Old October 27th 06, 09:21 PM posted to rec.aviation.piloting
Jose[_1_]
Maybe. But it costs weight and money. This means that, for the same
flight, the plane carries less gas, and this is the leading cause of
crashes. One could fly with more fuel stops, this increases the number
of landings and takeoffs (and low altitude flight). Since there's less
money, the airplane might be less well equipped, and the pilot might be
less well trained. This increases the risk too.
Everything comes from somewhere.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Trip report: Cirrus SR-22 demo flight Jose Piloting 13 September 22nd 06 11:08 PM
Wing Loadings (was SR22 discussion) john smith Piloting 8 June 23rd 06 11:41 PM
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
