![]() "T o d d P a t t i s t" wrote in message ... "wright1902glider" wrote: If you hold a constant speed and pitch attitude, changing the throttle changes altitude. More specifically, changing throttle changes your rate of climb/sink, and there's a single throttle position where the engine is adding as much energy to the aircraft as it is losing from drag. If you open the throttle, the engine will produce more power and you'll gain altitude. If you close it, you will descend. Throttle controls thrust. Elevator controls pitch. Keep it simple................Karl "Curator" N185KG |
![]() karl gruber wrote: "T o d d P a t t i s t" wrote in message ... "wright1902glider" wrote: If you hold a constant speed and pitch attitude, changing the throttle changes altitude. More specifically, changing throttle changes your rate of climb/sink, and there's a single throttle position where the engine is adding as much energy to the aircraft as it is losing from drag. If you open the throttle, the engine will produce more power and you'll gain altitude. If you close it, you will descend. Throttle controls thrust. Elevator controls pitch. Keep it simple................Karl "Curator" N185KG Attitude + Power = Performance. You can't say that one control does only one thing. There's too much reductionism in flight training and it creates inept pilots. Dan |
alexis park inn and aviation videos | Peter Duniho | Piloting | 49 | March 30th 06 10:34 PM |
$1295.00 Guaranteed Multi Ratings A+++++++++++ Service | NW_PILOT | Piloting | 22 | March 11th 06 01:07 AM |
House OKs ban on flag burning, Do Something. | [email protected] | Naval Aviation | 4 | June 24th 05 12:08 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
