Gary Drescher wrote:
I was just looking at the NACO chart for GLS ILS 13 (http://makeashorterlink.com/?I14153A5A). Curiously, there's no exemption from the procedure turn, even for the feeder route from HUB to SWANE. So should you fly from HUB to SWANE, make an uncharted procedure turn outbound, then turn around and come back in? Or is there a chart error? Yes, make the procedure turn unless you're vectored to the final approach course. What do you mean "uncharted"? There's a procedure turn barb on the chart. There's a note "Procedure turn N/A for Cat E", so if you're Cat E you need to have vactors for the final approach course, or use some other approach. Must be some terrain or obstruction within the protected area for Cat E. |
"Dave Butler" wrote in message
news:1107182845.199592@sj-nntpcache-5... Gary Drescher wrote: I was just looking at the NACO chart for GLS ILS 13 (http://makeashorterlink.com/?I14153A5A). Curiously, there's no exemption from the procedure turn, even for the feeder route from HUB to SWANE. So should you fly from HUB to SWANE, make an uncharted procedure turn outbound, then turn around and come back in? Or is there a chart error? Yes, make the procedure turn unless you're vectored to the final approach course. What do you mean "uncharted"? There's a procedure turn barb on the chart. For the inbound procedure turn, yes. The outbound turn would have to be flown after reaching SWANE inbound. I emailed NACO about this chart, and they replied promptly that the omission of NoPT for the HUB feeder is indeed a chart error, and will be corrected in the next revision. --Gary |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
GPS approach question | Matt Whiting | Instrument Flight Rules | 8 | November 1st 04 10:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
