Another SR22
Old October 27th 06, 07:22 PM posted to rec.aviation.piloting
Jim Logajan
Default Another SR22
Larry Dighera wrote:
However, if you have, for example, an engine failure at 400' on
departure, the CAPS is not an option.
My point is, that CAPS is not an option at the times it's needed most:
below 920'. So to characterize the SR22 CAPS as a safety enhancement
(for other than spin recovery, and possibly a MAC, structural failure,
loss of control, and landing in inhospitable terrain, *if* they occur
above 920') is inappropriate.
The Nall Report (NR) indicates the phase of flight with the most fatal
pilot-caused accidents (~78% of all fatal accidents) is during what it
calls "maneuvering" (~23%). Since the NR categorizes descent/approach,
landing, go-around, and takeoff/climb distinct from maneuvering, the
maneuvering category would appear to encompass flight regimes presumably at
pattern and cruise altitudes. I would presume then that CAPS would be a
viable option in a large fraction of these cases.
Looking at the way the NR categorizes pilot caused fatal accidents, it
seems to me that about half the categories are such that the fatalities
could in theory have been prevented with CAPS. So CAPS might have been
potentually life-saving in about 0.78*0.5 = ~40% of all fatal GA accidents.
The non-pilot caused accidents allegedly accounted for ~22% of accidents,
but the fraction that happened at altitudes sufficient for effective CAPS
deployment is unknown. Assuming SWAG of ~50% of those 22% happened at
altitudes high enough for CAPS use, then CAPS would be potentially life-
saving in ~11%.
So in theory if all GA craft were equipped with CAPS and pilots were
trained in their effective use, they might cut the number of fatalities in
GA accidents by roughly half.
Old October 27th 06, 07:47 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Oct 2006 18:22:34 -0000, Jim Logajan
wrote in :
Pattern altitude for light GA aircraft is typically 800' AGL, so it's
not clear that SR22 CAPS would fully deploy from that altitude. Even
at a 1,000' pattern altitude, the aircraft would likely be below 920'
before the PIC realized the necessity for deploying the SR22 CAPS.
What sort of maneuvering above 920' AGL would cause a fatal mishap,
other than a MAC?
So you feel that the PIC in those fatal accidents would have had
sufficient altitude to assess the nature of the emergency and decide
to deploy the CAPS with 920' feet to spare?
I'm having a difficult time thinking of what the cause of such
accidents might be. CFIT doesn't fit. I agree, that a MAC might
permit a pilot to deploy a CAPS, unless it was similar to November 16,
2000 C-172 vs F-16 MAC that disintegrated the pilot and his Skyhawk.
I'd have to know more about the nature of the criteria you used in
arriving at that conclusion before I'd accept it.
saving in ~11%.
Only if one accepts your assumptions.
Old October 27th 06, 09:21 PM posted to rec.aviation.piloting
Jose[_1_]
Maybe. But it costs weight and money. This means that, for the same
flight, the plane carries less gas, and this is the leading cause of
crashes. One could fly with more fuel stops, this increases the number
of landings and takeoffs (and low altitude flight). Since there's less
money, the airplane might be less well equipped, and the pilot might be
less well trained. This increases the risk too.
Everything comes from somewhere.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 28th 06, 02:42 AM posted to rec.aviation.piloting
Peter Dohm
in
Jose
A lot of excellent points. Like many of the safety features on cars, I
suspect that it would be essentially a wash in terms of safety--at a
substantial increase in cost.
Peter
Old October 28th 06, 02:29 AM posted to rec.aviation.piloting
Ron Lee
Or at a far lesser cost (and viable since CAPS may not be retrofit to
all aircraft) is that pilots quit screwing up in a manner that kills
them and others onboard.
Ron Lee
Trip report: Cirrus SR-22 demo flight Jose Piloting 13 September 22nd 06 11:08 PM
Wing Loadings (was SR22 discussion) john smith Piloting 8 June 23rd 06 11:41 PM
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
