![]() "Dick Meade" wrote in message ... OK, so how does this work? Two years ago, enroute OSH for the fly-in, I approach Madison with flight following. I'm given vectors, despite the fact I'm at 11,500 feet. Just how far up does their airspace extend? The last I heard Madison approach airspace went up to 10,000, it's possible it's been moved up to 13,000 to be consistent with Milwaukee approach which it abuts. If you were at 11,500 and talking to Madison approach that would seem to be the case. |
link.net... "Dick Meade" wrote in message ... OK, so how does this work? Two years ago, enroute OSH for the fly-in, I approach Madison with flight following. I'm given vectors, despite the fact I'm at 11,500 feet. Just how far up does their airspace extend? The last I heard Madison approach airspace went up to 10,000, it's possible it's been moved up to 13,000 to be consistent with Milwaukee approach which it abuts. If you were at 11,500 and talking to Madison approach that would seem to be the case. You mean that they will handle IFR traffic up to that altitude not that their controlled space goes up that high. The charted space for Madison is up to 4900 (or something close, I'm not looking at the chart). If I pass overhead of that or under or around, I will monitor but not bother them. However, Madison controllers are extremely accomodating. I have never had them vector me at all. The only time that even came close was a "... transition approved. Cross directly over the airport to stay clear of traffic." Milwaukee, on the other hand, seem very territorial. They are difficult to deal with for practice approaches at Kenosha and they aggressively protect their airspace around MKE by vectoring VFR traffic well clear. Many years ago, I was passing along the lakeshore under their airspace. I called up as a courtesy, got a squawk, then a chewing out for flying so close to their airspace, then vectors further out into Lake Michigan. I responded, "Lake 94P, squawking 1200, will remain clear of your airspace." I've never called them again unless inbound to MKE. If their airspace is busier than the protected areas are designed to support, I sympathize. If they want my cooperation, they need to be nice about it ___________________ Travis. |
: them again unless inbound to MKE. If their airspace is busier than the
: protected areas are designed to support, I sympathize. If they want my : cooperation, they need to be nice about it Exactly my sentiments. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() "Travis Marlatte" wrote in message m... You mean that they will handle IFR traffic up to that altitude not that their controlled space goes up that high. The charted space for Madison is up to 4900 (or something close, I'm not looking at the chart). If I pass overhead of that or under or around, I will monitor but not bother them. However, Madison controllers are extremely accomodating. I have never had them vector me at all. The only time that even came close was a "... transition approved. Cross directly over the airport to stay clear of traffic." I meant what I wrote. The controlled airspace delegated to Madison approach control does not appear on any chart readily available to the flying public. The charted Madison Class C airspace is just a fraction of their delegated airspace. Madison will provide Class C services to all aircraft within the Class C airspace and to all participating aircraft within the outer area. The outer area extends up to the upper limit of the controlled airspace delegated to them within a twenty mile radius of Truax Field. If you're talking to Madison approach within that area you're a participating aircraft and are subject to being vectored if need be to effect separation. Milwaukee, on the other hand, seem very territorial. They are difficult to deal with for practice approaches at Kenosha and they aggressively protect their airspace around MKE by vectoring VFR traffic well clear. Many years ago, I was passing along the lakeshore under their airspace. I called up as a courtesy, got a squawk, then a chewing out for flying so close to their airspace, then vectors further out into Lake Michigan. I responded, "Lake 94P, squawking 1200, will remain clear of your airspace." I've never called them again unless inbound to MKE. If their airspace is busier than the protected areas are designed to support, I sympathize. If they want my cooperation, they need to be nice about it He was completely out of line to chew you out for flying close to the Class C boundary. You can fly right up to the boundary without talking to them. But what courtesy were you extending by calling them? |
: He was completely out of line to chew you out for flying close to the Class
: C boundary. You can fly right up to the boundary without talking to them. : But what courtesy were you extending by calling them? A few I can think of offhand: - Providing altitude verification of your Mode-C readout. - Providing lateral intentions so they do not have to worry about rouge VFR targets. - Providing altitude intentions. In short by communicating, the pilot is providing the controller peace of mind that they are competent and do not present a potential "airspace incursion" threat by bumbling into their airspace. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote in message ... A few I can think of offhand: - Providing altitude verification of your Mode-C readout. - Providing lateral intentions so they do not have to worry about rouge VFR targets. - Providing altitude intentions. In short by communicating, the pilot is providing the controller peace of mind that they are competent and do not present a potential "airspace incursion" threat by bumbling into their airspace. Why would a controller assume you're competent merely by establishing communications? Establishing communications precludes an airspace incursion, of course, because establishing communications grants entry. But establishing communications makes you a participating aircraft that must now be provided services, including separation from any IFR aircraft he may be talking to whereas before he just needed to advise that IFR traffic of your target. In short, calling him will likely only increase his workload. I don't see how increasing his workload can be considered extending him a courtesy or providing him peace of mind. |
.net... In short, calling him will likely only increase his workload. I don't see how increasing his workload can be considered extending him a courtesy or providing him peace of mind. That's good value out of this discussion. My belief was that, if they had positive indication of my intent, that it would make life easier. Now I know that I should keep my mouth shut. ------------------------------- Travis Lake N3094P PWK |
"Steven P. McNicoll" wrote: In short, calling him will likely only increase his workload. verifying your Mode C altitude doesn't help descrease his workload? -- Bob Noel Looking for a sig the lawyers will hate |
![]() "Bob Noel" wrote in message ... verifying your Mode C altitude doesn't help descrease his workload? Probably not. Sure, if the Mode C altitude is verified he wouldn't have to be called as traffic to participating aircraft that are clear of his altitude. But to verify the Mode C he has to call and be identified, which now makes him another participating aircraft for which services must be provided. Having more participating aircraft tends to increase the workload, not decrease it. |
Ok. Now I am calling your bluff. One thing is totally wrong with your
comments. If I am on flight following/ VFR advisiories, whatever you want to call it and I am flying from JAC to SLC, I am in communication with ATC for over an hour. As I approach Class Bravo airspace around Salt Lake City, if I don't hear those magic words " CLEARED INTO CLASS BRAVO AIRSPACE" and I fly into the valley I can assure you I will hear " CALL THE TOWER" upon landing. Being in communication with enroute does NOT clear me into Bravo airspace or "grant" me entry. My next beef is your attitude toward "participating" aircraft. If I fill my fuel tanks with 100LL and pay all taxes that are included with each gallon I can assure you I want all services that are available to me. For you to whine about increased workload is not my problem. Your agency and employer, "the federal government" has collected taxes from me from the fuel I bought, it is up to your system to provide me with all services included with said taxes. Now, I would love to see two fuel pumps at all airports, one that collects taxes and then I would be a "participating" aircraft. The second pump would be 100LL, or mogas that charged no taxes and I would fly VRF and never deal with you whiners.... What say you now??? Steven P. McNicoll wrote: wrote in message ... A few I can think of offhand: - Providing altitude verification of your Mode-C readout. - Providing lateral intentions so they do not have to worry about rouge VFR targets. - Providing altitude intentions. In short by communicating, the pilot is providing the controller peace of mind that they are competent and do not present a potential "airspace incursion" threat by bumbling into their airspace. Why would a controller assume you're competent merely by establishing communications? Establishing communications precludes an airspace incursion, of course, because establishing communications grants entry. But establishing communications makes you a participating aircraft that must now be provided services, including separation from any IFR aircraft he may be talking to whereas before he just needed to advise that IFR traffic of your target. In short, calling him will likely only increase his workload. I don't see how increasing his workload can be considered extending him a courtesy or providing him peace of mind. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
