Tow Hitch Ball - 50mm or 2"?
Old October 28th 06, 04:51 AM posted to rec.aviation.soaring
Default Tow Hitch Ball - 50mm or 2"?
I use this set up for all of my trailers - 1 7/8", 50mm & 2":
http://www.convert-a-ball.com/
They don't list the 50mm ball on their website but they have them if
you ask.
Steve
ContestID67 wrote:
I needed to move a Blanik L23 trailer over the weekend. Using my 2"
tow hitch ball and I had a heck of a time disconnecting the two. I
knew that the Blanik trailer has what I assume is a 50mm tongue.
I was kind of surprised that my 2" ball (which works out to be 50.8mm)
would be a problem disconnecting. 8/10's of a millimeter difference
doesn't seem like enough to worry about.
What is the tolerance on a 2" setup? Is it so close that 0.8mm can be
a problem?
Thanks, John
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Wanted - Ball Vario parts [email protected] Soaring 0 September 22nd 06 05:56 AM
Why don't wings have dimples? Dancing Fingers Home Built 56 June 17th 06 11:54 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 03:05 AM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
