Why no plywood monocoque homebuilts?
Old October 28th 06, 08:01 PM posted to rec.aviation.homebuilt
Default Why no plywood monocoque homebuilts?
Orval Fairbairn wrote:
In article .com,
" wrote:
Morgans wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote
The hard part would be to come up with a reasonable replacement for the
spars
in the wings. To avoid the big expensive spruce planks, one might have to
consider an engineered product like Laminated Veneer Lumber (LVL)...
Have you ever used those? They are HEAVY, with a capital "H".
SNIP
Jim in NC
Jenny Craig strikes again :-)
I am still very intriqued by filament winding. Spars would probably be
most obvious use of this technology. Take a look at the pictures on
this page to get an idea why.
http://www.boatdesign.net/forums/sho...11160b889f2560
2fba&t=1774&page=2
Doesn't that kindof suggest the ability to make a whole spar, wing,
fueselage or control surface in one shot? I am presuming scaled
composites uses something similar but bigger. I've seen pictures of the
system NASA uses for booster casings, they stand about 20 ft. tall if
I remember correctly.
I will be checking the local yellow pages to see if there are any
mast-makers where I live. I'd like to take a closing look at a system
like this.
-Matt
Actually, filament winding would be a poor choice for spars, as the
filaments should run primarily parallel to the spar and be concentrated
at the top and bottom. You do need some in the webs, to handle shear
loads, but an "I" section is the most efficient. A tubular spar for a
wing is also a poor choice, as it concentrates a lot of its tensile
strength at its center, where it doesn't get much loading.
Couldn't that be controlled by adjusting the weave? Perhaps weave in
three angles instead of two, with the third being parallel to the
length axis? The form could be semi-rectangular as well, which would
give you your ability to concentrate fibers on the top and bottom.
Obviously you can't escape some wastage, but "perfect" is the enemy of
"good enough".
A mast is a different story, as it is expected to take similar bending
loads in all directions; a spar does not.
Are you quite familiar with filament winding? I've got a lot of
questions if you've got the time.
-Thanks
-Matt
Old October 28th 06, 09:07 PM posted to rec.aviation.homebuilt
Orval Fairbairn
In article .com,
In article .com,
spars
have to
SNIP
Jim in NC
http://www.boatdesign.net/forums/sho...ec4011160b889f
2560
2fba&t=1774&page=2
like this.
-Matt
"good enough".
Filament winding wraps the material (carbon, Kevlar, glass, etc.) around
the item, whereas you want the filaments in the spar caps to run
longitudinally, because that is the direction of tensile and compressive
stresses. Filaments wrapped around the spar will carry shear stresses,
but are of little help in taking up bending loads, which comprise the
major stresses in a spar.
I haven't done any filament winding, but I am familiar with
filament-wound rocket motor cases.
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 05:26 PM
Air Conditioning System for Homebuilts? JPAviation Home Built 18 February 6th 04 03:24 AM
Homebuilts by State Ron Wanttaja Home Built 14 October 15th 03 08:30 PM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 08:02 PM
