Common instruments on small aircraft
Old October 29th 06, 08:16 AM posted to rec.aviation.piloting,rec.aviation.student
Default Common instruments on small aircraft
On 29 Oct 2006 00:00:05 -0700, "Bart" wrote:
Bart wrote:
As for GA, I've been trying to make a trip for two weeks now, but
haven't been able due to weather. If I had needed to, I could have made
the trip in a car and been back home the same day two weeks ago. I put
it off because I'm using it as an excuse to fly - which I believe is
what most GA pilots probably do.
To make my point even further, I just recieved an email from a member
of my flying club that battery in our plane is dead.
If this were a car it would be no big deal since I could go to an auto
parts store and replace the battery myself. But since we need a
licensed A&P mechanic to do the job, and there's not exactly one on
every corner, we'll have to wait in line to get the job done.
The pilot or operator of a Part 91 aircraft can replace the aircraft
batteries...you don't need an A&P. Read 14CFR 43.3(g) and Appendix A (c).
Old October 30th 06, 03:34 AM posted to rec.aviation.piloting,rec.aviation.student
Bart
Ok - but we still have to wait on the battery to be ordered which takes
at least a day.
Old October 30th 06, 05:15 AM posted to rec.aviation.piloting,rec.aviation.student
RK Henry
at least a day.
Did someone just leave the master switch on? Can't you just charge the
battery?
I've never had a battery just die. It usually exhibits its death
throes for months, giving plenty of time to shop Trade-A-Plane for the
best price.
RK Henry
Old October 30th 06, 05:39 PM posted to rec.aviation.piloting,rec.aviation.student
Bart
at least a day.
battery?
best price.
We've been having issues with it for awhile. Nobody has been able to
figure out exactly what the problem is.
Old October 31st 06, 07:49 PM posted to rec.aviation.piloting,rec.aviation.student
Grumman-581[_3_]
"RK Henry" wrote in message
best price.
I've had it happen with a car battery before... Starting my car after work,
it turned over normally and I thought that it had started and released the
key... Turned out that I had done it too quick and the car hadn't started...
Tried to start it again and all I got was a slight clicking noise... Just
barely enough juice to make the lights on the radio dimly glow... Car
batteries are not any different than aircraft batteries... Same basic
technology, thus same failure modes... Yeah, it could happen on an aircraft
battery also... My experience though is that this sort of failure mode is
rather rare since I've only had this sort of thing happen once for any
vehicle battery that I ever owned...
Old October 30th 06, 03:37 AM posted to rec.aviation.piloting,rec.aviation.student
Bart
We still have to wait on the battery to be ordered which takes at least
a day. And assuming the best case scenario of it getting put in
sometime tomorrow, I will then be forced two wait at least another two
days due to weather.
Old October 30th 06, 04:06 AM posted to rec.aviation.piloting,rec.aviation.student
Bart
Bart wrote:
I will then be forced two wait at least another two days due to weather.
Oops. My brain got ahead of my typing. The above should read "I will
then be forced *to* wait..." grin
Grumman-581[_3_]
"Bart" wrote in message
Depending upon what type of plane we're talking about and whether the plane
is close by and the flight can be made in daylight, one option might be to
jumpstart or hand prop the aircraft and fly it back to your home field... Or
grab a battery out of another plane and take it there for temporary use to
get back to your home airport... I've had a battery die (or drain because of
leaving something on) before and I just hand propped it and flew it back...
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
