On Sun, 29 Oct 2006 03:34:05 GMT, Jose wrote:
So, each year a bit less than one percent of the fleet bites it. The rate seems to be increasing slightly in the last few years, but the sketchiness of this data precludes a conclusion based on that. To compare with the Cessna fleet (bearing in mind the errors in the year data due to registrations), I'll just add the last five years of fleet size, getting something like 125,000. Five years of accidents at a 3/4% rate (the last five years of the Cirrus rate, eyeballing it) would imply something like a thousand C-172 crashes. So, were there "something like a thousand" C-172 crashes in the last five years? From January 1st, 2002 to December 31st, 2004, the GA average fleet accident rates were as follows: Overall: 0.58% Homebuilts: 0.80% Rotorcraft: 1.63% Robinson: 3.83% Cessnas: 0.56% Cessna 172: 0.62% Piper: 0.47% Piper Super Cubs: 1.02% Beech: 0.45% Beech 33, 35, & 36: 0.43% To get the above results, the total number of accidents in the three-year period were divided by the total aircraft of that type registered on 1 January 2005, and the result divided by three to produce a yearly average. Note that the Beech, Cessna, and Piper figures may be artificially low, due to old aircraft that are still on the registry but not actively flying. Aircraft can be abandoned or even scrapped without telling the FAA, hence they remain on the register. The FAA is currently working on weeding out these old registrations. I haven't run the fleet accident rates for the Cirrus....guess maybe I'll have to take a look. If, as you say, the accident rate is about 0.75%, that's in the ballpark of the 172. Ron Wanttaja |
On Sun, 29 Oct 2006 01:37:47 -0700, I wrote:
I haven't run the fleet accident rates for the Cirrus....guess maybe I'll have to take a look. If, as you say, the accident rate is about 0.75%, that's in the ballpark of the 172. Just completed a cursory look at the accident data. A summary on the process: I previously downloaded the NTSB accident report databases for the years 2002, 2003, and 2004 and developed various database queries to allow analysis of accident causes. I've also downloaded the FAA registration database every January for the past ~7 years. I have developed various tools to allow comparison of accident rates. Rather than compare the Cirrus accident rate to those of the overall fleet of Cessna 172s, I have compared it only to the accidents involving 172s manufactured since 1994 (yes, production started a few year after this point). I have included any Cessna 172 listed with a post-1994 manufacture date, PLUS all Cessna 172R and 172S models since the year of manufacture is not always available). For both aircraft, I have included only those accidents that occurred in the United States. After looking at my tools again, I see my earlier posting mis-stated my method of determining the total fleet size of a particular aircraft. I had stated that I used the January 2005 FAA registration database to determine the fleet size. This is incorrect. In reality, my tool determines the *average* of the fleet size from January 2002 to December 2004. It is this average that is used to calculate the fleet accident rate. There are other ways of making these determinations, but it by using the same processes for both types of aircraft, the *relative* rates for each can be obtained. Ah, the heck with it...on to the data: Cirrus Accidents during subject period: 20 (over a 3-year period) Late-model 172 Accidents: 103(over a 3-year period) Average Cirrus Fleet Size: 783 aircraft Average Late-model 172 Fleet Size: 1993 aircraft Average ANNUAL Fleet Accident Rates: Cirrus: 0.85% Late-Model 172: 1.72% However, here's an interesting point: The C172 is used for instruction, while the Cirrus is not. The NTSB lists none of the 20 Cirrus accidents as occurring during instruction, while 68 of the late-model 172s are so listed. If you eliminate the instruction accidents from the late-model 172 accidents, the 172 rate drops to 0.59% *if* you assume the same fleet size. However, to be an honest comparison, the fleet size would have to address only those aircraft flown for personal pleasure or business...an almost impossible task. In any case, the fleet rate would be higher. From this data, I don't think the Cirrus rate stands out excessively. Ron Wanttaja |
Ron Wanttaja wrote: Average ANNUAL Fleet Accident Rates: Cirrus: 0.85% Late-Model 172: 1.72% However, here's an interesting point: The C172 is used for instruction, while the Cirrus is not. The NTSB lists none of the 20 Cirrus accidents as occurring during instruction, while 68 of the late-model 172s are so listed. If you eliminate the instruction accidents from the late-model 172 accidents, the 172 rate drops to 0.59% *if* you assume the same fleet size. However, to be an honest comparison, the fleet size would have to address only those aircraft flown for personal pleasure or business...an almost impossible task. In any case, the fleet rate would be higher. From this data, I don't think the Cirrus rate stands out excessively. How does the Cirrus rate compare to the late model 182 accident rate, or the late model Bonanza accident rate? Those are more likely to be used for travel, like most Cirrus planes. John -- John Clear - http://www.clear-prop.org/ |
Ron,
From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. -- Thomas Borchert (EDDH) |
![]() From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. Peter |
Peter,
It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'd say so. But mind you, saying so already made me an "apologist" here. Which brings me to another reason for the increase, with regard to the pilot community, not the media: the introduction of gasp "something new" (tm). -- Thomas Borchert (EDDH) |
inconsistancy of small samples have simply increased the hype factor. I'd say so. But mind you, saying so already made me an "apologist" here. Which brings me to another reason for the increase, with regard to the pilot community, not the media: the introduction of gasp "something new" (tm). That's a really good point, and the specter of being thought of as an apologist for an airplane that I really don't like does hang over me quite heavily. ;- I suppose that I should be grateful that the safety record is approximately average instead of demonstrably above average, just to avoid the apologist label, but I'm not. I'm just not sold on the lack of demonstrated spin recovery (with the chute as a backup) and the controls felt awkward and possibly tiring when I sat in one on static display. |
Peter Dohm wrote:
From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. Matt |
"Matt Whiting" wrote in message
Peter Dohm wrote: From this data, I don't think the Cirrus rate stands out excessively. Dick Collins did the same analysis for new 182s and Cirrus. Same result. It does seem like the parachute, an occasional a celebrity, amd the inconsistancy of small samples have simply increased the hype factor. I'm sure that is the case. Then again, if a chute equipped airplane has the same accident rate as a traditional design, I think one must question the value of having the chute and its associated cost and weight. It makes the pax happy. I have one in my ultralight and I've always thought that the odds of it being the right choice in an emergency are very slim. Of course, the people saved by them would probably install one again at twice the cost... moo |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
