I'd say more important is the altitude at which one flies. Low to the
ground, even with a zillion hours, a WAC is next to useless. Up where you need oxygen, sectionals may lose their appeal. True. But on a long cross country, even in the middle altitudes, WACs are so much nicer to deal with. I guess you don't fly low cross countries. I like to go CT to FL at five hundred feet. A thousand over some parts. A WAC won't cut it there. ![]() Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
hundred feet. A thousand over some parts. A WAC won't cut it there. ![]() What're you flying, Jose? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
A Dakota. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
A Dakota. You fly a Dakota, cross-country, at 500 feet? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I like to. But it's usually more like 1000. There are many more towers now than there used to be, and the East coast is more dense than the Mojave desert. (I used to fly up and down the desert like that twenty years ago before there =were= cell phones - I probably picked up an extra ten or twenty knots just from pitching down into the rising heated air.) I plan the flight very carefully, checking the sectional for towers (knowing they aren't all there), for airports and frequencies, terrain, parachute drop zones, and anything else that might be significant that low. It's all written out in a log ahead of time, plotted on the sectional, obstacles circled (they make good landmarks actually), quadrant minimum altitudes logged, and I make sure I have good visibility to do it in, and a high enough ceiling to climb if I need to. Planning a long flight like that can take as long as actually flying it - there's a lot I can ignore at 8000 feet that is critical on the deck. To do it without detailled planning like that, in low viz, under scud, is suicide. But on a nice day with careful planning, it is not only (relatively) safe, it is excellent XC practice. I have the GPS on in case I need it, but turned to a text page so I don't cheat. At that altitude you can't see the whole world below you, so you'd better hold a good course, pick good landmarks, be on top of your timing, and pay attention. Try it. Practice it. It may save your butt one day. Have you calculated your glide range from 500 feet? The fan stops, yes, I have fewer options. Of course, it's much safer to fly as a passenger in a jetliner. We fly little airplanes because the joy of flight is worth the risk. There are tradeoffs all over aviation. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
Jose wrote:
You fly a Dakota, cross-country, at 500 feet? I like to. But it's usually more like 1000. There are many more towers now than there used to be, and the East coast is more dense than the Mojave desert. (I used to fly up and down the desert like that twenty years ago before there =were= cell phones - I probably picked up an extra ten or twenty knots just from pitching down into the rising heated air.) And where did that rising heated air come from? If you were flying in a straight line, then you likely aren't netting any gain from thermals as you also are flying through the corresponding downdrafts. Matt |
"Matt Whiting" wrote in message
... And where did that rising heated air come from? If you were flying in a straight line, then you likely aren't netting any gain from thermals as you also are flying through the corresponding downdrafts. In fact, he was missing his opportunity. As has been discussed here before, in rising air the right thing to do is slow down and let it carry you up. Then you dive as you fly through the descending air you're sure to find (which you mention). He can either take the assistance as fuel savings, or trade that for a higher power setting that will get him to his destination faster. But by diving in the updrafts, he's throwing away any possible savings, and probably comes out behind when he has to slow down to maintain altitude in the downdrafts. Pete |
The sun heats the ground. The ground heats the air. The air expands and goes up. Cooler air comes in from the outside of the desert, not from above me. Sure, there are some downdrafts, but the net is up. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
And I thought I was the only one that did that (500 ft AGL, that is)!!!
Jose wrote: I guess you don't fly low cross countries. I like to go CT to FL at five hundred feet. A thousand over some parts. A WAC won't cut it there. ![]() |
The view is awesome, especially in fall, over rolling hills. But keep a sharp eye for cell towers! Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
Can ATC assign an airway if filed direct? | Andrew Sarangan | Instrument Flight Rules | 26 | March 4th 04 12:23 AM |
