#29
![]() Orval Fairbairn wrote: Actually, filament winding would be a poor choice for spars, as the filaments should run primarily parallel to the spar and be concentrated at the top and bottom. You do need some in the webs, to handle shear loads, but an "I" section is the most efficient. A tubular spar for a wing is also a poor choice, as it concentrates a lot of its tensile strength at its center, where it doesn't get much loading. A mast is a different story, as it is expected to take similar bending loads in all directions; a spar does not. The spar in my Jodel is a one-piece box spar and is the only spar in the wing. It takes the lifting and landing loads, the drag loads, and the torsion loads. The washout is built into it. It's about 7" deep and 12" wide at the center. It has four lumber members, one in each corner of the box, and the top two are larger than the bottom two, since wood is stronger in tension than it is in compression. Plywood diaphragms maintain the box shape and the whole thing is closed with plywood skins with the outer plies at 45° angles to take advantage of the maximum directional strength of the wood. The lumber members are heaviest at the center and lightest at the tips. The dihedral is in the outer panels, and the lumber members are spliced at those points. Shrike had suggested building wooden airplanes with semi-skilled labor; I don't think I'd want such a spar as this to be built by someone who wasn't either thoroughly trained and apprenticed or who would be eventually flying it. It's a most elegant piece of engineering and is the most complex and time-consuming part of the whole airplane. One foolish mistake in jigging or gluing could just about trash the whole thing. Dan |
compound curves in plywood | BA-100 | Home Built | 58 | April 13th 05 05:29 AM |
cvjetkovic ca-65 skyfly- plywood spar? | patrick mitchel | Home Built | 3 | October 16th 04 05:26 PM |
Air Conditioning System for Homebuilts? | JPAviation | Home Built | 18 | February 6th 04 03:24 AM |
Homebuilts by State | Ron Wanttaja | Home Built | 14 | October 15th 03 08:30 PM |
Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 08:02 PM |
