On 30 Oct 2006 21:38:13 -0800, "abripl" wrote:
Hey Bill, Do I detect some humor here? Most of us are concerned with general fuel savings - not just for our own I bought the Deb to play. I'm building the G-III to play. The only time it runs under 75% is when maneuvering, practicing, rought air, or landing. immediate savings. But you know that higher general consumption results in higher prices at the pumps which means the poor guys (most of us) indirectly pay for the "enjoyment" of those with lots of money. So let's have prudent enjoyment. I leave the 18 mpg SUV home and drive my wife's 48 mpg Prius. I only drive the 4 Runner when I need to haul something messy, or she's gone with her car. So even if I take a trip and run the Deb for all she's worth I still save gas. Badwater Bill wrote: Oh come on you guys, you can't justify any of this. These modern, expensive airplanes are no different that owning a boat or even a Lear Jet. It's not a neccesity, it's not something required to enjoy life. If you can't own it and just go burn all the gas you want to burn through it, you shouldn't even get it. Anyway, that's the way I feel. I didn't buy it so I could get 20 mpg out of it. It's just interesting that I do. ............... Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Roger (K8RI) wrote: I leave the 18 mpg SUV home and drive my wife's 48 mpg Prius. I only drive the 4 Runner when I need to haul something messy, or she's gone with her car. So even if I take a trip and run the Deb for all she's worth I still save gas. Now all I need is to buy a second larger plane for ocasional larger hauling or when my wife wants to fly separately at same time. Otherwise of course I will use my smaller canard for most flying. |
On 31 Oct 2006 17:42:26 -0800, "abripl" wrote:
Roger (K8RI) wrote: I leave the 18 mpg SUV home and drive my wife's 48 mpg Prius. I only drive the 4 Runner when I need to haul something messy, or she's gone with her car. So even if I take a trip and run the Deb for all she's worth I still save gas. Now all I need is to buy a second larger plane for ocasional larger hauling or when my wife wants to fly separately at same time. Otherwise of course I will use my smaller canard for most flying. Hmmm... I only have one and a quarter airplanes. I'm not even half way there yet and the G-III will have a larger engine than the old Deb. OTH it should go a lot farther on the same gas. BTW I see some environmental groups are pushing for the elimination of lead in Avgas. Then I won't be able to use either engine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger (K8RI)" wrote in message
BTW I see some environmental groups are pushing for the elimination of lead in Avgas. Then I won't be able to use either engine. Reset the timing and use different power settings. Some parts of the world already don't have avgas (and no FAA to stifle experimenting). D. |
On Wed, 08 Nov 2006 02:28:45 GMT, "Capt.Doug"
wrote: "Roger (K8RI)" wrote in message BTW I see some environmental groups are pushing for the elimination of lead in Avgas. Then I won't be able to use either engine. Reset the timing and use different power settings. Some parts of the world already don't have avgas (and no FAA to stifle experimenting). With that high compression engine? You can't even get an STC for an alternative fuel. D. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Roger (K8RI) wrote: On Wed, 08 Nov 2006 02:28:45 GMT, "Capt.Doug" wrote: "Roger (K8RI)" wrote in message BTW I see some environmental groups are pushing for the elimination of lead in Avgas. Then I won't be able to use either engine. Reset the timing and use different power settings. Some parts of the world already don't have avgas (and no FAA to stifle experimenting). With that high compression engine? You can't even get an STC for an alternative fuel. Time to get GAMI back on the stick and get PRISM certified. Then your engine would run on Jet-A okay. Trouble is, with their new contracts with Cirrus, I'm afraid PRISM is small potatoes on the back burner. |
With that high compression engine? You can't even get an STC for an alternative fuel. Where STCs are not a consideration, high RPMs and less than full MAP can allow the use of autogas. Performance may take a hit, and sometimes timing must be retarded for the turbocharged engines, but it works. I ran autogas in my first Aztec (NOT US registered!!!!!!) for years. The only difference was that I had to turn on the boost pumps on above 7000' for vapor lock. D. |
On Thu, 09 Nov 2006 02:58:44 GMT, "Capt.Doug"
wrote: "Roger (K8RI)" wrote in message With that high compression engine? You can't even get an STC for an alternative fuel. Where STCs are not a consideration, high RPMs and less than full MAP can allow the use of autogas. Performance may take a hit, and sometimes timing To me performance is paramount. I'm building the G-III to go as fast as possible. Long haul and some serious play. I don't even run the Debonair under 75% except for maneuvers, a rough ride, and landing. That engine IO-47N (260 HP) doesn't qualify for an STC either. My goal is to get similar HP to the one shown in KitPlanes this month. must be retarded for the turbocharged engines, but it works. I ran autogas in my first Aztec (NOT US registered!!!!!!) for years. The only difference was that I had to turn on the boost pumps on above 7000' for vapor lock. D. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
BWB has finished his Lancair Legacy... | John Ammeter | Home Built | 1 | June 6th 06 04:11 AM |
A friend of mine is building a Legacy and has a question.... | John Ammeter | Home Built | 14 | April 23rd 06 11:17 PM |
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 0 | March 15th 04 02:32 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
Lancair Legacy 2000 | Randy L. | Simulators | 6 | October 9th 03 09:56 PM |
