Discus verus Discus 2, LS8, ASW 28
Old October 31st 06, 01:58 PM posted to rec.aviation.soaring
Shawn
Default Discus verus Discus 2, LS8, ASW 28
Jack wrote:
Tom Smith wrote:
Tom,
I'm happy to see that you share my view that the DG-303
is incomparably better than the rest of the standard class field, and
that any disparity in competition achievement is probably due to the
relative
quality of the pilots and/or numbers of aircraft built.
Jack,
You’re clearly suffering from a serious case of delusion!
Your equating the DG-303 with the 2006 Carerra GT in
their respective fields was apt indeed, though the 'turd' reference
was perhaps a little harsh on the competition.
I note that you are not a member of SSA. From what
material does one usually build a glider in your corner of the universe?
Funny you should ask; the rest of the universe has
been wondering the same thing about your corner. We
had concluded that your glider manufacturers had discovered
how to isolate and work the ugly atom. Perhaps you
could confirm or dispel these rumours.
Many thanks,
Tom
See:
http://www.soaridaho.com/Schreder/
http://www.glidersport.net/
http://www.continuo.com/marske/
http://www.agcsc.org/sgs_1_34_info.html
http://www.windward-performance.com/
http://www.ssa.org/JohnsonLWBX/Genesis2%202000-03.pdf
The problem is not a lack of appreciation for either aerodynamics or
aesthetics, but a matter of production costs and exchange rates. Those
challenges will be overcome.
We're sure taking care of the exchange rate portion of the problem :-p
Shawn
P.S. Happy Halloween! Of all the hijacked religious holidays, this one
has the best movies. :-)
Old October 31st 06, 02:36 PM posted to rec.aviation.soaring
Jack
Shawn wrote:
Jack wrote:
Tom Smith wrote:
Tom,
relative
Jack,
universe?
Many thanks,
Tom
See:
Not, obviously, by direct assault. Nanotech might do it, unless you
actually wanted a glider big enough for your body.
Jack
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
All Czech built Discus grounded Paul Soaring 0 September 14th 03 02:22 AM
18m Discus Burt Compton Soaring 2 September 8th 03 10:52 AM
Discus Wing question John Galloway Soaring 6 August 23rd 03 07:52 AM
