A disturbing statistic
Old November 1st 06, 01:35 AM posted to rec.aviation.ifr
Jose[_1_]
Default A disturbing statistic
I was including this kind of business flying as "personal flying". Do
the statistics separate it out?
Yes - and it is MUCH safer.
Does this "business flying" include bizjets? That would skew the
statistics. I would include (as personal flying) only that business
flying that is piloted by the person wanting to make the trip.
I would be interested in a rule you
would consider a net good.
Well, it was not my stated position that they existed, merely that the
potential for the other (rules that are not a net good) does. But ok,
let me try to think: (I'm on Usenet; I'm out of practice!)
1: requirement for an instrument rating to fly IFR.
2: BFR/wings
3: (old?) requirement for minimum VFR hours before pursuing an
instrument rating (learn how to look out before we teach you to look in)
4: More stringent requrements for a commercial or ATP rating.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 1st 06, 03:06 AM posted to rec.aviation.ifr
RK Henry
On Tue, 31 Oct 2006 00:14:52 +0000 (UTC),
(Dane Spearing) wrote:
According to the DOT, the 2005 automobile fatality accident rate is:
1.47 fatalities per 100 million miles traveled
(see
http://www-fars.nhtsa.dot.gov/)
According to the 2005 Nall Report, the general aviation fatality accident rate
is: 1.2 fatalities per 100,000 flight hours
(see http://www.aopa.org/asf/publications/nall.html)
In order to compare these two statistics, we obviously need to assume an
average velocity for either automobiles or GA aircraft. If we assume an
average GA aircraft velocity of 150 mph, then the aviation accident statistic
becomes 1.2 fatalities per 15 million miles.
The 2005 Nall report shows a total 1413 GA accidents, fatal and
non-fatal, or 6.22 accidents/100,000 flight hours. Applying the
assumed average cruising speed of 150, the 6.22 accidents becomes
41.47 accidents per 100 million miles.
According to NHTSA, there were an estimated 6,159,000 police-reported
motor vehicle accidents in 2005, of which there were 43,443
fatalities. Dividing the 43,443 by the 2,965 billion miles traveled is
where they got the figure of 1.47 fatalities per 100 million miles.
Dividing the 6,159,000 accidents by the same 2,965 billion miles gives
an accident rate of 207.72 accidents per 100 million miles traveled.
It appears that if you drive a car, you're 5 times more likely to be
involved in an accident than if you fly, even in a General Aviation
aircraft. Since you have to have had some kind of accident in order
for it to be fatal, this is somewhat encouraging.
The problem is that airplanes go so much faster. If you do have an
accident at 150 mph, you're more likely to die as a result, whether
you're in a car or an airplane, and airplanes are much less
crashworthy than automobiles. One might speculate what the fatality
rate for automobiles could be if cars routinely cruised at 150 mph,
even if such speeds didn't bring with it an even higher accident rate.
Examining automotive fatality and accident rates in places like
Germany, where in some parts high speed driving is commonplace, might
be instructive. Only 0.7% of those automobile accidents were fatal
while 20% of the aircraft accidents were fatal. Airplanes don't crash
as often, but when they do, it's bad.
Perhaps one conclusion is that more attention should be paid to making
aircraft accidents survivable. Some work has already been done in this
area, but it looks like there's much room for improvement.
RK Henry
Old November 1st 06, 05:02 AM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
No matter how you present the statistics, GA flying has a higher
fatality rate than driving. But one has to look at all the factors when
evaluating a mode of transportation. Nothing beats walking for safety,
plus it is good for your health too. Yet many people take the car for
even short distances. While GA flying is more convenient, faster and
flexible compared to driving, and even compared to airline travel, they
come at a certain amount of risk. Some people choose to accept that
risk, and some won't. It is better to be aware of the risks in flying
rather than pretend they don't exist, or assume they don't apply to
you.
(see
RK Henry
Old November 1st 06, 10:28 AM posted to rec.aviation.ifr
Jim Macklin
Much of the risk is controllable. Weather is never a
surprise anymore. modern weather satellites and automated
observations are not perfect, but some caution and honest
self-evaluation of a pilot's actual skill level could
eliminate ,any accidents.
JFK Jr. died because he did not have the skill to make the
flight under the conditions which existed at the time he
actually made the flight. The airplane was just fine, the
weather was OK for an IFR rated pilot or a VFR pilot who had
be taught properly how to use the equipment available. He
had lots of instruction, maybe too much instruction and not
enough developed judgment. Perhaps the instructors he had
used did not have "real" experience and thus failed to teach
the procedures that could have saved his plane and the
passengers.
Lidle had a fast airplane and a CFI. But it appears they
simply flew into box without any proper planning. Slow
flight and steep turns, evaluation of the wind, knowing the
East River procedures would have saved his life. Using the
radio to get a clearance would have too. What will never be
known, were they looking at the GPS track or out the damn
windows at the river and shore line?
You can practice the East River turn anywhere, pick a road
or river and practice a 180° turn within the confines of the
allotted space. You can even learn when an airspace
violation is better than dying.
James H. Macklin
ATP,CFI,A&P
"Andrew Sarangan" wrote in message
higher
factors when
for safety,
the car for
faster and
travel, they
accept that
risks in flying
apply to
| you.
accident rate is:
| (see
need to assume an
If we assume an
fatal and
Applying the
accidents becomes
police-reported
43,443
miles traveled is
million miles.
billion miles gives
miles traveled.
likely to be
General Aviation
accident in order
do have an
result, whether
less
the fatality
at 150 mph,
accident rate.
places like
commonplace, might
were fatal
paid to making
been done in this
improvement.
| RK Henry
Old November 1st 06, 10:33 AM posted to rec.aviation.ifr
Sam Spade
Michael wrote:
Sam Spade wrote:
But, my
observations over 50 years of being around this stuff tells me that
experienced pilots seldom crash on good VFR daytime operations.
True enough. However, my observation is that pilots who limit
themselves to nothing but good VFR daytime operations never do become
experienced (they quit after a few hundred hours because flying just
isn't useful under those restrictions), so that doesn't help.
Michael
Depends whether the self-imposed limit is imposed going into the game or
much later on after the cat has shed several lives. ;-)
Old November 1st 06, 11:25 AM posted to rec.aviation.ifr
Bob Noel
In article . com,
yet my most serious accident occurred while I was walking
and required surgery, a 14 day hospital stay, was out of
work for more than to months, and I'm still recovering.
Nothing is 100% safe.
Bob Noel
Looking for a sig the
lawyers will hate
Old November 1st 06, 12:04 PM posted to rec.aviation.ifr
Jim Macklin
"Jim Macklin" wrote
in message ...
| eliminate many accidents.
had
not
teach
| passengers.
be
| James H. Macklin
| ATP,CFI,A&P
| higher
| factors when
walking
| for safety,
| the car for
| faster and
airline
| travel, they
| accept that
| risks in flying
don't
| apply to
|| you.
| accident rate is:
|| (see
aviation
| need to assume an
aircraft.
| If we assume an
| fatal and
| Applying the
| accidents becomes
| police-reported
| 43,443
| miles traveled is
| million miles.
| billion miles gives
| miles traveled.
| likely to be
| General Aviation
| accident in order
| do have an
| result, whether
| less
| the fatality
| at 150 mph,
| accident rate.
| places like
| commonplace, might
| were fatal
| paid to making
| been done in this
| improvement.
|| RK Henry
  #28
Dan Luke
"Bill" wrote:
Here's a thought exercise that will get you in touch with this data.
1) How many people do you personally know that have been
wiped out in airplanes? (my answer--quite a few; way too many)
2) How many people do you personally know that have been
wiped out in car accidents? (my answer--have to struggle to
remember more than a couple, one of whom was
ironically a pilot)
3) How many more people do you know who drive than fly?
(personal answer: Many X)
Might be more useful to compare flying to those who ride motorcycles.
Or ask yourself: how many celebrities can you name who have been killed in
plane crashes vs. the number kiled in car crashes? In the former, quite a
few; in the latter, just a couple.
Now ask yourself: how much time do celebrities spend travelling in airplanes
vs. the time spent in cars?
Dan
C172RG at BFM
  #29
Old November 1st 06, 12:41 PM posted to rec.aviation.ifr
B A R R Y[_2_]
allotted space.
Anybody remember "S-Turns" from the PP-ASEL PTS?
Linked 180's...
  #30
Old November 1st 06, 02:07 PM posted to rec.aviation.ifr
Sam Spade
Michael wrote:
Sam Spade wrote:
But, my
Michael
The OP stated,
I've had many non-pilot friends and co-workers ask, "Is flying a small
plane more or less dangerous than driving a car?", to which my response
has always been "It depends on who is piloting the plane."
Your observation is from the pilot perspective. A better answer to the
OP would include both pilot experience and type of operation.
I have always admonished my non-flying friends and relatives to only fly
with an experienced pilot and only during solid Day VFR conditions.
That will fit them into the safety slot I feel they deserve to be in.
If the pilot who they fly with chooses to fly at other times during the
night in IMC, dodging TRWs in the Rockies with his XM weather display,
that risk is not imposed upon those I am advising.
request for fighter pilot statistic gatt Piloting 64 December 21st 05 10:55 PM
Very disturbing article about air safety JJ Instrument Flight Rules 10 July 22nd 04 08:56 AM
