How do you find the limits of areas on a chart?
Old November 1st 06, 09:56 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default How do you find the limits of areas on a chart?
I see tons of restricted areas, MOAs, Class B, C, D, E airspace, and
the like on charts, but no clear indication of how to locate the
boundaries of these areas other than by pure guesstimate based on
looking at the chart. On rare occasions I see a radial noted as the
boundary of an area, or a radius, but in many cases there is nothing.
How in the world are you supposed to know when you are inside or
outside one of these areas, if you are not flying miles away from
them?
Yes, GPS units and some other devices may provide real-time display of
one's position with these areas superimposed, but such devices have
not always been available.
Old November 1st 06, 10:19 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
Mxsmanic wrote in
them?
The sectional depicts the borders very clearly, and it depicts the terrain
surrounding those borders as well as any nearby navigation aids.
To learn how to read a sectional, I would recommend Whitt's Flying site. It
has very useful and detailed lessons for a student who wants to learn how to
fly. And best of all, it's free.
http://www.whittsflying.com/
Old November 1st 06, 10:23 PM posted to rec.aviation.piloting,rec.aviation.student
Neil Gould
Recently, Mxsmanic posted:
Reading a chart, like many other things, is a process that requires
knowledge. One gains this knowledge by studying. Once you have studied and
gained the necessaryt knowledge, you will know that there is no
"guesstimate" involved in knowing the boundaries of areas on a chart. You
have been given ample resources by many posters that would enable the
average person to research and answer this question on their own. Why not
give that a try?
Neil
Old November 1st 06, 10:43 PM posted to rec.aviation.piloting,rec.aviation.student
Dave Doe
says...
them?
You can use your instruments and you can use your eyes. You get
clearances (if required) *before* you enter an area. When climbing out
and under VFR you ensure you remain below TMA's by the same technique -
well *before* the area.
If IFR, you fly what you're told - if you think the controller's made a
mistake (because of what you can see on the charts), then asking for
clarification might be wise.
You might like to note the differences between IFR charts and plates vs
VFR charts (which, if you look, are really maps - topo maps).
Duncan
Old November 1st 06, 11:02 PM posted to rec.aviation.piloting,rec.aviation.student
The Visitor
Neil Gould wrote:
You
give that a try?
I had a funny though,t that a person could write a learn to fly a
simulator book; comprised of cut and pasted poster's answers to all
these various questions. ??? Every aspect it seems if being covered.
Old November 1st 06, 11:21 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
Judah wrote:
Mxsmanic wrote in
Today most of us just hold the wing off the red line on the GPS. We can
thread some pretty tight areas with GPS today.
-Robert
Old November 1st 06, 11:59 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Do you mean how do you find the boundary as depicted on the chart, or
how do you relate the depicted boundary to an actual physical location
out in the real world?
If the former, there's a legend printed on every chart.
If the latter, when all else fails, some pilots fall back on an advanced
technique that is all but forgotten in this age of GPS. It's called
"looking out the window for landmarks."
rg
Old November 2nd 06, 01:11 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Judah writes:
Yes, but it provides no directions or dimensions (with a few
exceptions). Am I expected to pull out a protractor and a ruler in
flight to check the chart and see if I really am clear of airspaces I
wish to avoid?
I'll try it.
Old November 2nd 06, 01:12 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
The Visitor writes:
The ideal simulator can be flown by a real pilot with no special
instruction at all. That's why it's called a simulator.
Old November 2nd 06, 01:13 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Dave Doe writes:
I've been able to find sectional charts and terminal charts at
SkyVector, but where can I find IFR charts?
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
chart heads-up Jose Instrument Flight Rules 2 September 29th 06 07:25 PM
Sectional Chart Question Teranews Piloting 27 June 23rd 05 12:14 AM
WAC Chart Images on line? Rich Owning 5 March 22nd 04 11:17 PM
